Deck With Not Enough Space For Beams And Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 08:18 PM   #1
Question
Deck with not enough space for beams and joists
I'm a beginner and planning to build a deck. The local lumber yard gave me a plan, which calls for 2x10 beams and 2x8 joists. The problem is I only have about 12" from my sliding door to the ground. What options do I have? I could dig out the ground around the deck, but am concerned that it may ruin the integrity of the slab my home sits on.
Any help would be appreciated.
alexeygu is offline   Reply With Quote
Old 06-21-2010, 09:59 PM   #2
DIY staff
Rewards Points: 7,174
When there is not room under the deck----set your beams so that the top of the beam is at joist level and hanger the joists off the side of the beam instead of setting the joists on top--
There isn't that just as clear as mud!
Could someone else step in here--I have a splitting head ache tonight.---Mike--
drtbk4ever (06-22-2010)
Old 06-21-2010, 10:27 PM   #3
Rewards Points: 1,910
What O'mike said will work fine.
You can use smaller depth beams by supporting them at more frequent intervals with posts/piers. Since you won't be walking under a 12" high deck it doesn't matter how close together the posts/piers are. Same with the joists, they can be smaller depth if the beams are spaced closer together. Just means more holes and concrete. So in theory you could use 2x6 for joists and beams by spacing the posts right.
But honestly, I'd put in a patio (brick, stone or concrete) instead of a deck that low. It will never rot, sliver, fade or warp.
The Following User Says Thank You to jogr For This Useful Post:
oh'mike (06-22-2010)
Old 06-22-2010, 06:23 AM   #4
Framing Contractor
Flush beam using joist hangers on all joists. Same amount of footings. No additional footings and concrete.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-22-2010, 07:49 AM   #5
Old School
Willie T's Avatar
This is a good way. The only problem you may encounter is mid deck support. In this case, you will simply have to approach it as two decks butted to each other, using back-to-back hangers on a common single beam.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 06-22-2010, 01:51 PM   #6
Handyman
Rewards Points: 512
Maybe try metal saddle posts? I know they're a pain to pound into the ground but might work best for you. Keep the 2x8's lower than the 2x10's equal to the thickness of the deck boards) and frame the perimeter the same way...gives a nice clean edge finish.
canadaclub is offline   Reply With Quote
Old 06-22-2010, 03:44 PM   #7
kwikfishron's Avatar
Rewards Points: 372
2x10 beams ?
kwikfishron is online now   Reply With Quote
Old 06-22-2010, 06:28 PM   #8
Rewards Points: 5,336
That low to the ground I would put in a stone patio. Wood decks are an upkeep pain in the ass. They start to die as soon as you install them.
Ron
Old 06-22-2010, 06:42 PM   #9
Handyman
Rewards Points: 512
hmm..adam said that about eve
catch you folks in a month, after my ban!
Alex, can we see he plan?
The Following User Says Thank You to canadaclub For This Useful Post:
Old 06-22-2010, 08:09 PM   #10
Without any idea of the spans etc its kind of hard to offer much assistance
I agree I'd put in a patio, that's what I did at my last house
Old 06-22-2010, 09:00 PM   #11
Learning by Doing
Leah Frances's Avatar
I don't get it. Adam said Eve started to die after he installed her? Next time you are required to be controversial and funny before anyone will consider a ban.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Space between Bottom of Deck and Ground BSponz1 Building & Construction 3 05-18-2010 11:40 AM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 03:23 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
