Old 06-21-2007, 11:55 AM   #1
Deck Nails
Sorry if this is a ridiculously easy or stupid question but...Can I use "16d bright common" nails for a pressure treated deck?
memetic is offline   Reply With Quote
Old 06-21-2007, 12:16 PM   #2
RippySkippy's Avatar
Deck Nails
Can you? Yes.
Should you? NO!
You need to use a fastener that offers corrosion resistance i.e. galvanized. Are you talking about framing construction or decking fastening?
Personally I won't use nails for PT deck construction, I far prefer construction screws rated for PT contact. More expensive, but IMO far superior.
RippySkippy is offline   Reply With Quote
Old 06-21-2007, 12:33 PM   #3
Deck Nails
Yeah it's for the framing. I already bought the screws you mentioned, the thing is I am putting up the hangers now and I think I should use nails for those?
Old 06-21-2007, 12:40 PM   #4
Deck Nails
Pressure treated or ANYTHING outdoor needs to have hot dipped galvanized (galvanized nails). Do NOT use bright common. They will rust and break.
cibula11 is offline   Reply With Quote
Old 06-21-2007, 12:42 PM   #5
Deck Nails
I am working on my deck right now. Use 8d or 10d galvanized nails for the hangers. They usually come 1 1/2" . I then toenailed the joists to the ledger using 3" 16d. Just please don't use anything other than galvanized.
And yes, for structural applications you must use nails NOT screws.
Old 06-21-2007, 12:48 PM   #6
Deck Nails
There are special nails for the hangers, short stubby hot dipped galvanized...much like these. Use them...they're the right thing to use, plus they won't hardly bend...a plus for this application. There are other brands but search'em out.
Old 06-21-2007, 09:09 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Deck Nails
As stated:
All exterior applications: Galvanized or Stainless fasteners, NEVER brights.
Pressure Treated lumber for use ANYWHERE: Galvanized or stainless because anything else will corrode due to the CAQ preservative treatment of the lumber.
Additionaly, DO NOT USE ALUMINUM FLASHING with Pressure Treated lumber. Use approved copper deck flashing only.
- Build Well -
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be estimating materials. First we are going to need some cedar boards that will be replacing the area that we are going to cut out. Next we are going to need some medal flashing so that... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. When you are inspecting underneath you want to make... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be installing our new material. To install our material we are going to be using galvanized nails, now galvanized nails aren't going to rust or break down over time. Before we install... Read More »
Hi. My name is Michael Raines and I'm with Expert Village. The first step is making Hydrogen. It's an electrolysis process. Basically, current flowing through two pieces of metal. Now we're going to use one of these little tubes. This is going to be our... Read More »
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck - beam to post connection (??) brocasArea001 Carpentry 17 06-26-2007 10:54 AM
Deck. Can I use nails instead of srews? BalchConstruction Building & Construction 14 05-11-2007 05:14 PM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
