Old 09-09-2008, 01:53 PM   #1
deck for a mobile home
We want to build a deck for our mobile (manufactured) home. We've been told that because our home is on pilings rather than a foundation, we should NOT attach the deck to the side of the house. The deck height will need to be almost 4 feet. Any advice on how to stabilize a deck this high that is not attached to the house?
rln17 is offline   Reply With Quote
Old 09-09-2008, 02:14 PM   #2
Are you living in a mobile home park? If you aren't, then the most logical would be to dig post holes, pour a concrete footing, put the posts in(Size depending on your span you need to cover), and build your deck off of this base structure.
If you aren't in a mobile home park and would like some more specifics, please post back and I'm sure we can all help to walk you through the process as best we can via text and diagram
Northern_Sunrise is offline   Reply With Quote
Old 09-09-2008, 05:51 PM   #3
No, we are not in a park. We are on an acreage in northern alberta. Our soil is mostly hard packed clay and difficult to dig, but I suppose we can rent an auger to dig post holes.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 47 03-20-2013 10:48 AM
Cover for a deck on a Mobile Home Oilerz General Discussion 1 05-10-2008 11:40 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Can I set a cabin on top of mobile home slab? birchbarx Building & Construction 4 03-22-2008 07:06 PM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 11:12 AM
