Deck Ledger Screws Maybe Too Long, Help!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 11:31 PM   #1
Deck ledger screws maybe too long, help!!
Ok I am building a deck, the plans via lowes called for 1/2x6inch lag bolts that would be counter sunk for the to make them flush with the legder. The lag bolt only have 3inches of thread on them. When I look in the basement 2.5inchs of the thread are through the beam of the house and exposed. Is this ok???? If not I had planned to go with 1/2x4inch lag bolts and just place them a few inches over from the 6inch ones that are now sealed with caulk. The deck is 16x16 with 2 sides on the house, and supported via 6x6 lumber in 6 locations. Thanks for the help
appledamian is offline   Reply With Quote
Old 05-03-2010, 12:01 AM   #2
You are asking if 1/2" of threads will hold ??
I'd say that is definitely not OK
What are these lag bolts holding in ?
The ledger board ?
Old 05-03-2010, 07:58 AM   #3
yes ledger, the threads are all the way through.
Old 05-03-2010, 08:13 AM   #4
kwikfishron's Avatar
Rewards Points: 92
Just swap them out to 4”. You probably should step up to 5/8” so you get a good bight in the same hole.
kwikfishron is online now   Reply With Quote
Old 05-03-2010, 10:31 PM   #5
Registered User
Rewards Points: 4,924
The plans call for counter-sinking the lag screw heads and washers?
Be safe, Gary
Old 05-04-2010, 07:55 AM   #6
Rewards Points: 92
If you can access the back then forget the lags and through bolt.
Questions on a deck I just built. stearns86 Carpentry 50 10-12-2009 11:17 PM
Composite Deck Screws John_F Carpentry 32 07-16-2009 11:12 AM
Repair collapsed deck jdoerz Building & Construction 17 07-11-2009 11:22 AM
Ledger and Deck Remodel Mr.S Teacher Building & Construction 5 07-02-2009 09:48 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
