Deck Ledger Needed For Non-load Deck Attachment? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 01:38 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,346
Deck Ledger needed for non-load deck attachment?
I'll be building a deck that wraps around a corner.
What do I do with the side that doesn't need a ledger?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-18-2010, 01:45 PM   #2
kwikfishron's Avatar
Rewards Points: 430
Run a joist, ledger to ledger.
kwikfishron is offline   Reply With Quote
Old 06-18-2010, 03:51 PM   #3
I have gas!
Thanks,
Would it would be attached to the wall as well or run siding behind it?
Old 06-18-2010, 06:59 PM   #4
Rewards Points: 430
What’s the span, you’re using 2x?
Were are the beams located?
The rest of the drawing would help.
Old 06-18-2010, 08:20 PM   #5
I have gas!
I don't have a real drawing yet as the deck isn't fully planed out/
What I'm doing now is siding. I'll probably build the deck next summer but I'm putting the ledgers in now to accommodate the ledger flashing and siding placement.
This newer picture gives a better idea but still far from a drawing I'd bring down to the building department.
I plan on 2x8s on everything with the longest joist span under 8' and beam span at about 6'.
So should I take a ledger to that six foot section or side that wall and place a double joist next to it?
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 12:29 PM
Deck Ledger Fasteners ovahimba Building & Construction 6 01-09-2008 11:16 PM
Painted deck - advice needed! Sallie Painting 5 03-22-2007 11:03 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
need help with deck ledger weekender Carpentry 3 10-02-2005 10:32 PM
