Deck Ledger Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 11:27 AM   #1
Deck ledger installation
In the process of installing a new deck, 40ft x14ft. I plan to install the 40ft 2x10 PT ledger board (multiple 2x10 board lengths) to the house, and not sure if the crown should be installed "UP" or "DOWN"?
rcassidy is offline   Reply With Quote
Old 04-24-2012, 11:56 AM   #2
cortell's Avatar
Rewards Points: 504
I would go crown up since your joists will also be oriented that way, but I think it's mostly a moot point. You hopefully picked ledger boards that are mostly straight. You're going to be fastening them to existing structure with lag screws located along the length of the board, before any load is put on them. Thus the board will not have the opportunity to deflect--the main reason for going crown UP on joists.
cortell is offline   Reply With Quote
Old 04-24-2012, 11:58 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Crown up.
- Build Well -
Old 04-24-2012, 03:33 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
crown up always. but where your talking about the ledger find the straightest wood in the pile for the ledger. it should get anchored every 32 " max which eliminate deflection..
its harder to put a badly crowned ledger on than it is to do with something thats straight. with the latter you just tack it to the level chalk line then bolt it on
woodworkbykirk is offline   Reply With Quote
Old 04-24-2012, 04:06 PM   #5
Rewards Points: 12,820
And it needs to be flashed if it's attched to the rim joist of the house.
I space my ledgers out with 1 X 6 vinly lumber sitting vertical as shims so the water can not lay there and rot out the ledgers.
Old 04-25-2012, 07:29 PM   #6
robertcdf's Avatar
Or go steel and you won't have to think about crown.
robertcdf is offline   Reply With Quote
Building a deck with 4x10s on a ledger and beam KrisWithak Building & Construction 5 03-27-2011 10:37 AM
New Deck Ledger Regulations Ron6519 Building & Construction 1 02-07-2011 12:11 AM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Deck installation Sharon713 General DIY Discussions 3 04-27-2008 02:53 PM
