#1 |
Deck Ledger To House Osb Rim Joist
I have a free standing deck that I am building attached to our newly built house. My question is that the we used 12" laminated I beams for the house, and the builder used an OSB 3/4" for the house rim joist. I do not see adequte strength in the OSB to lag bolt my deck ledger to the house? There should not be any down weight on the ledger since it was built as a free standing deck, my only concern is if the deck would try to shift away from the house over time. Should I just re-inforece the house rim joist by cutting 2x12 sections to fit inside between the house floor joist & then bolt the ledger to them through the OSB. Thank you
#2 |
Custom Deck Builder
In addition to installing the 2x12 blocking, cut plywood inserts to fill in the webbing of your I-joists, both sides, on either side of each 2x12 blocking. That way, you've got a solid surface to nail your blocking to the floor joists. Nail your webbing inserts together with a staggered pattern using 8d nails
- nail into your 2x12 blocking ends w/ 12d or 16d nails. Best to use galvanized hex or carriage bolts w/ built up oversized galvanized washers (1/2 bolt, use 1/2", then 3/4" washer. Make sure bolt holes are properly waterproofed and stagger their location (height-wise) on the ledger board to help prevent splitting. Strapping is another really good way to tie your deck to your house if your deck joists are in line with your house joists. Simpson MSTA straps - cut a vertical slit in the house rim joist lined up with the side of your house and deck joists, slide a 36" ZMAX strap through it and use 10d nails to nail it to the side of your deck joists and your house joists. Use a strap on each end of your deck and one in the middle, if it's longer than 20'. Again, you'll want to fill in the webbing of those house I-joists w/ plywood on both sides so the strap is nailed to something solid, not just 5/8" of OSB. Mac |
#3 |
BuilderRemodeler
Blocking is good. Bolting directly to your framing members or into the floor joists can also be done for added strength.
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online!
#4 |
Moderator
I wouldn't advocate doing too much to your i-joists. If you do, keep the nails in the top and bottom flanges to a minimum. Nothing larger than a 12D box nail into the flange!!! I don't see any need to make huge efforts to secure the blocking to the joists.
You're not actually bearing the deck, and the rim board is reasonably strong. I'd use carriage bolts and large washers on both sides, and perhaps install some 2x material on the interior side of the rim to spread the load a little. Be sure to space the deck rim joist off the house a little bit to prevent rot. |
#5 |
If the house isn't supporting the deck why attach it to the house at all? These days even 2nd floor decks are built w/o attaching to the house, too many water infiltration issues.
#6 | |
Moderator
Deck Ledger To House Osb Rim JoistQuote:
Water infiltration issues are easily mitigated with good installation practices. |
#7 | ||
Custom Deck Builder
3/4" OSB face-nailed to the ends of I-joists is not a strong connection for shear forces that would pull the deck away from the house - 2 nails every 16" into plywood endgrain. To strengthen that connection, the interior blocking needs additional nailing, hence the web fillers. Quote:
I've not seen ANY second floor decks built freestanding w/ no connection to the house. What part of the country are you in that you see this type of construction? Termite's got it - flashed and sealed properly, water intrusion is not an issue. Mac |
#8 |
BuilderRemodeler
Munsons on top of things - 2 x 12 Blocking is good.
As stated by Mac - web fillers also prevent gap. Bolt it solid as described. My Understanding of free standing two story decks is this takes real understanding of framing and is often not advised. Often Decks are slightly lowered where you can also attach to framing (Treated sill) for downward pressure and initial securement. Keep Web Blocking slightly less than the total height. Appreciate Mr. Termites comments on watching attaching into the floor joists. You do not want to crack your I joist flanges.
| Display Modes | |
| Attaching deck ledger to cantilever | ram80ran | Building & Construction | 13 | 04-18-2009 01:29 PM |
| replacing rotted sill plate and rim joist behind a deck ledger board | tommyt | Building & Construction | 2 | 08-11-2008 08:38 PM |
| House shingles rotting where outside deck attaches.... | LI_Deck_Guy | Building & Construction | 4 | 05-20-2008 07:36 PM |
| The Bioswale, french drain, deck, drainage dilemma (long) | seabright_sc | Building & Construction | 2 | 01-05-2008 04:37 PM |
| Installing deck ledger board over foam board? | RickT | Building & Construction | 5 | 11-06-2006 11:50 PM |
