Deck Ledger Flashing Installation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 12:32 PM   #16
Contractor - Renovations
fungku's Avatar
Originally Posted by amakarevic View Post
so are you saying that i don't need any flashing on the house side because the connect material there is concrete ? and also, what kind of nails should i use for the flashing on the shed side ?
Roofing nails should probably do the trick for you
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
amakarevic (02-07-2011)
Old 02-07-2011, 12:33 PM   #17
Rewards Points: 1,062
thanks. how about the flashing on the house ledger side (see question above)?
Old 02-07-2011, 12:41 PM   #18
Originally Posted by Daniel Holzman View Post
As for the flashing, that should extend up at least six inches above the ledger, mine extends about 10 inches above, and is nailed into the house high up. I caulked each nail hole with silicone. The flashing is bent around the ledger, and does not actually touch it.
i don't get the "six inches above the ledger" part ...
Old 02-07-2011, 12:43 PM   #19
fungku's Avatar
kinda like this pic I found on google. # 6 is the flashing, but I'd use the peel n' stick between them.
you'd nail the flashing to the wall and not the ledger.
Old 02-07-2011, 12:53 PM   #20
fungku's Avatar
as for the ledger attached to concrete, is this your foundation wall, below your framing and cladding?
Old 02-07-2011, 01:00 PM   #21
there is no framing, the house addition is build with large brick elements (kind of like cinder blocs but clay, and then has cement over it). but the ledge below the double sliding door is all solid concrete, 82" wide, about 18" deep, 2.5' high, i poured it a few months ago and rebared the crap out of it. dude, it's rock solid, a mortar attack couldn't harm it. on the house side, the deck mostly rests on it and then two small ledgers on both side that go into the legacy addition wall (i broke holes on the hollow elements and filled them with mortar and then epoxied the bolts in, it is also rock solid).
Old 02-07-2011, 03:48 PM   #22
fungku's Avatar
I'm havin a tough time following you.
Got photos?
amakarevic (02-08-2011)
Old 02-08-2011, 02:50 AM   #23
Question
Got photos?
will post some later. but the bottom line is if a ledger is affixed on a concrete wall, it does not need flashing, true or false?
Old 02-08-2011, 03:02 AM   #24
fungku's Avatar
generally, true if there is nothing other than concrete behind the ledger
Door threshold flashing at deck kwerk Building & Construction 7 10-28-2010 12:06 PM
Deck ledger vs band board wvw Building & Construction 2 06-02-2009 03:18 PM
Do I have to remove stucco to attach deck ledger? brandon272 Carpentry 5 04-03-2009 09:57 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck installation Sharon713 General DIY Discussions 3 04-27-2008 01:53 PM
