Deck Leaks Even With Z Flashing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 02:27 AM   #1
Deck leaks even with Z flashing
Hi guys, (sorry I will post some pictures on this issue tomorrow). I have a walkout deck/balcony. It looks like water is leaking to my basement wall thru the deck. (the whole wall is wet - this is where the ledger attached). The house is L shaped so my walkout deck is attached to the L shaped ledger. The deck has Z flashing installed I noticed the water leaks more at the L corner of the deck so my question is:
If the Z flashing is installed. Is there any other ways the water can come in?
Because of the L Shaped ledger/deck, I noticed the Z flashing is overlapping each other at the L corner, would this cause the leak?
Can the water get underneath the Z flashing and leaks behind the ledger board?
newbieguy is offline   Reply With Quote
Old 06-13-2012, 05:56 AM   #2
Remodeling Contractor
it could. This is why we use ice and water membrane behind the ledger and then flashing over the deck ledger board. It is also better to space the ledger board away from the building at least 1/2"
Old 06-13-2012, 06:39 AM   #3
Rewards Points: 13,274
Or make them free standing.
Old 06-13-2012, 09:55 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
depending on the direction of the decking boards it is usually easiest to pull up a few deck planks to expose questionable leaky area and find the fix. with the decking out of the way you can see what is going on where the deck is attached at the house.
hand drive is offline   Reply With Quote
Old 06-13-2012, 03:22 PM   #5
The issue is that my wall is stucco..it's not easy to take out the Z flashing (is it??) .. but yes, I will pull up one or two planks closer to the flashing to take a look
Old 06-13-2012, 03:34 PM   #6
Hi guys, I just added a pix of my deck. My observation:
The flash doesn't look flush, could water leak in under the flashing to the ledger area.
Should I bend the flash down ward a bit so that the water can flow outside?
Old 06-13-2012, 06:32 PM   #7
Framing Contractor
How high was the stucco cut above the decking to properly flash it?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-14-2012, 12:10 AM   #8
AHH, SPANS!!!
stucco can be a tricky wall to get flashed correctly if the stucco guy did not flash it correctly in the beginning or if the deck was built with improper flashing.
Old 06-14-2012, 01:24 AM   #9
I agree. I think as long as the flash is behind the tar paper then that should do the trick but for my case, I might have to cut several inches of stucco to confirm if the flashing is indeed behind the tar paper. I was searching the net and noticed guys installed the flashing in front the tar paper, is this acceptable? I didn't think so but I'm not expert in this field.
Btw, another question, other than slight color differently, for stucco, can a contractor cut several inches and redo the stucco just for that part. I don't want to redo the whole wall just because of the flashing.
We had quite a heavy rain today for 2 hours and I went down to the basement and checked my wall where it was wet before. It was perfectly dry...now I'm puzzled. Is there any tests I should perform? I was expecting some water leakings after this heavy rain. I will post a picture of the deck after the rain.
Deck: gap from 1st deck board to wall frankkerfoot Building & Construction 2 05-16-2012 09:49 PM
Do I need deck flashing? rewzter Building & Construction 14 04-23-2012 06:36 PM
flashing help needed endgrainguy Roofing/Siding 3 12-31-2009 11:09 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
