Deck Knee Bracing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2013, 05:53 PM   #1
Rewards Points: 105
Deck Knee Bracing question
For a deck that is 9 feet above ground, what is the best way to attach knee bracing between the 8"x8" posts and the 3-2"x12" beams?
Should I use lag bolts all around or use galv carriage bolts on the post and galv lag bolts on the beam?
Bugman1400 is offline   Reply With Quote
Old 12-15-2013, 09:36 PM   #2
Registered User
Rewards Points: 5,520
Carriage, pp. 18, I think, or 16..... http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Old 12-16-2013, 12:22 PM   #3
Rewards Points: 105
That Guide suggests using a 2"x4" but, I don't think that is practical with 8"x8" posts and a 3-2"x12" beam. I also don't think it would look good to have the brace on the outside. Most knee bracing that I've seen is done more like what you see here:
http://www.beforethearchitect.com/Ar...e%20Braces.htm
Old 12-16-2013, 08:45 PM   #4
Registered User
I gave you minimum code requirements, you may do as you wish.....ask your local AHJ.
Gary
Unique deck question amcinnis1 General DIY Discussions 5 06-12-2012 09:52 PM
Deck structure question houseinthewoods Building & Construction 5 06-13-2010 09:18 PM
Question about refinishing a deck... Ler0y Jenkins General DIY Discussions 11 05-26-2010 09:09 AM
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 04:36 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
