Deck For Kid Clubhouse Thoughts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2015, 02:19 PM   #1
Rewards Points: 117
Deck for kid clubhouse thoughts
Ok, it's begun: Kid clubhouse
The first part is a simple 8 x 8, 30" above grade.
I just need some good guidance on the beam setup. The costs are similar, so I'm concerned about strength--planning 4x4 posts.
Should I go with a (strong tie) cap on the post and sandwich two 2x8's to make a beam, and then put the joist assembly in the beam.
Or, should I go with carriage bolts through the side of the post and 2x8.
I know the torsion (option b) to the side isn't the best but it's a small deck.
I've also seen this, which lets you put two beams over 3/4 of the post top.
https://www.google.com/shopping/prod...qLAsmCNvjUh_gC
Dornier is offline   Reply With Quote
Old 10-11-2015, 03:00 PM   #2
Rewards Points: 13,732
Build it the same as building any deck.
How long do you want this to hold up?
Not even sure what you would use those brackets for you posted for.
30" is going to require railings.
Is there going to be a building (club house) on top of this platform?
Any drawings, pictures of what you want to build?
Old 10-11-2015, 03:17 PM   #3
Rewards Points: 117
Thanks for answering
I'll post sketches. 8 x 8 and yes an 8x6 house(shed) atop it.
Old 10-11-2015, 05:38 PM   #4
Location will also help.
Want it to last then your going to need Sono tubes set below the frost line.
6 X 6's not 4 X 4's.
Post bases on top of the Sono tubes and notch the 6 x 6's to except the 2 X 8's and through bolt them with 1/2" carrrage bolts.
Old 10-11-2015, 06:00 PM   #5
Rewards Points: 117
SE TEXAS. No frost issues but I planned on using tubes.
I had a friend doing the same type project and he just 45'd the 2x8 and set them atop the posts. He's go straps to go on the sides to secure the post to the beams.
Hadn't seen that but it seems strong.
Old 10-12-2015, 11:46 AM   #6
Sippin' Tea
Sdyess's Avatar
Rewards Points: 110
I would double enforce it, as children seem to be pretty rough despite their size.
Sdyess is offline   Reply With Quote
Old 10-12-2015, 12:57 PM   #7
Rewards Points: 117
What do you mean? In reference to this photo of my friend's?
Old 10-12-2015, 12:59 PM   #8
Sippin' Tea
Sdyess's Avatar
Rewards Points: 110
In reference to joecaptions "Build it as any deck" and looking at the photo of your friends. Also he says 30" for railings. For children, I'd always include a railing.
Old 10-12-2015, 03:01 PM   #9
He wasted a lot of time cutting those at a 45, there's 0 reason to do that when framing.
Rim joist also should have been through bolted not just nailed.
If he just has those rim joist sitting on the post, where's the post caps to hold then in place?
Please do not follow this guys instrutions.
http://www.strongtie.com/products/co...urce=capsbscat
Old 10-12-2015, 03:51 PM   #10
Rewards Points: 117
Oh definitely the railing.
I think I'll stick with a standard deck beam (double 2x's) and go 16" OC. Maybe 18"
Based on the charts I see i can go posts/bearer at 0' , 5', and 10' on the 10 ft side, and just the ends of the 8ft side--using 2x8's
Old 10-12-2015, 11:28 PM   #11
9 times out of ten miter joints open up.
I would round all corners for child safety.
ron45 is offline   Reply With Quote
Old 10-14-2015, 09:37 AM   #12
Rewards Points: 117
Ok, I have a quick sketch and wanted to put down what I believe to be correct. However, there are a few grey areas I'm not certain of. It's a clubhouse, but I want the deck to last for the next family that lives here.
1. southeast TX so my frost line is shallow: Decks.com says about 5"
2. 8' x 10' outer dimensions
3. height is just about 30" (i need it low so the house can be higher and stay within my HOA guidelines)
4. beams will be sandwiched 2x8x10's with post caps sitting on 4x4's
5. 4x4s (see #4)
6. concrete footings, poured with sawed off sonotube, that is 12" diameter.
This is where it gets grey for me between technique and safety:
http://www.decks.com/how-to/40/beam-span-chart-table
***According to that chart--with my 8' joists--I can get away with only 4 corner posts (4x4), which are 10' apart on the long side, if I use 2x8 joists (and presumably rim too?).
***It also says if I want to use 2x6 joists I'd have to put a post at 4 or 6' on the long side (i was going for 5' for symmetry).
***2x6 joists (SYP) can go up to 9' which is more than I need, but I do have the clubhouse/shed going on top.
(btw, some of these charts differ slightly in their answers)
Q1. So, in terms of cost it's cheaper for me to go with 2x8's and fewer posts, but the house is at one end (8x6) and I thought putting posts halfway down the beam was a good idea anyway. Would 2x6 be ok or stick with the 2x8?
Q2. Is there any reason / any case where you would make your rim joists 2x8 and the actual joists 2x6? Or do they always match. Stupid question, but no literature online yet.
Q3. given that I'm down near the gulf coast in TX, a 12" footing (i'm over mostly clay and sand) could be poured literally 6 or 7" deep? Then just use a masonry bit to drill a post base in once it cures? I don't know if I trust my setting skills to put one in when it's plastic.
Q4. finally, how far in can the beam be from the rim joists? I can find charts on cantilever for beams hanging over posts (i'm doing about 12" for mine which is about 50% of the tolerance), but I'm not finding guidance on the beam.
(sketch)
As always, thanks for taking the time.
Old 10-14-2015, 09:54 AM   #13
How well are you with charts...?
Give us the exact description of the clubhouse, or you can look it up here.
http://ci.camarillo.ca.us/docs/bs/We...0Materials.pdf
Old 10-14-2015, 10:22 AM   #14
Rewards Points: 117
Without anything more than a sketch of the house I came up with about 310psf for the studs, roof, and framing.
This site says for two beams, 3 posts each, I should be fine on my clay/silty soil.
http://www.ideasfordeckdesigns.com/c...calculator.php
Old 10-14-2015, 10:30 AM   #15
Post the sketch here.
deck questions oregonhomeowner Building & Construction 3 09-10-2013 10:25 PM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
General questions re: platform deck with slanted roof trolle Building & Construction 4 04-15-2013 09:47 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
