Deck - Joists Bearing On A Beam Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 07:35 PM   #1
Rewards Points: 105
Deck - Joists bearing on a beam question
What do you guys use to secure the joists that are sitting on the beam? Do you use the Simpson H1 or H2 hurricane ties or just toe nail or screw?
Mucho thanks!!
Bugman1400 is offline   Reply With Quote
Old 06-16-2013, 07:39 PM   #2
Rewards Points: 13,450
Please go back and add your location to your profile, go to Quick links to edit.
This is a good question for your building inspector.
You are getting a permit, right?
Old 06-16-2013, 08:04 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
we typically use one or the other (H1 or H2.5) if the beam is below the joists. of course I'm in a hurricane wind area.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-16-2013, 09:25 PM   #4
Rewards Points: 105
I pulled a permit that cost me $154.00 and did so for safety reasons. The deck I'm building is ~9 ft off the ground so, I wanted to ensure my deck was safe for friends and family.
Old 06-16-2013, 10:06 PM   #5
GBrackins's Avatar
I do not know if you've already designed your deck or not, but I'd suggest reviewing this design guide put together by the American Wood Council which is based upon the requirements of the 2009 International Residential Code. http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
this document came about because of all the deck failures we've experienced across this great country of ours.
good luck!
Gary
Resting/Attaching Deck Roof Posts on Deck Beam... mgh-pa Building & Construction 12 06-06-2011 09:16 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Deck Beam Question usmcstormvet Building & Construction 5 08-28-2008 04:48 PM
