Deck Joist Spacing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2008, 09:06 PM   #1
Deck Joist Spacing
I built a 14'x14' deck, the frame is 4x6 footers and a pair of 2x6's are the outside joists (around the perimeter)
The floor joists I put at 34" OC, on the advice of a local shadetree carpenter who said 36" OC would be ok for floor joists on a deck. The purlins are at 48" OC.
each floor joist has 3 footers, all connections are done with Simpson Strong Tie 90* joist hangers.
The decking is all 2x6 PT #2, the framing is all #2
I am concerned about the floor strength, with joists at 34" because my father-in-law told me I should have them at 16"... when I walk on the deck I feel no give anywhere - how can I gauge the strength of the decking? Can I put furniture on it?
I don't think I can get under there to add joists, plus all the purlins would have to be removed. This would require removal of all decking...
What should I do?
udlooz is offline   Reply With Quote
Old 11-02-2008, 10:25 PM   #2
Rewards Points: 93
What should I do?
34" on center? I can't say I have ever heard of that. 12", 16" or 24" max. This shadetree guy you talked to wouldn't happen to be named Shannon Davidson?
When you say you can't get under there...how far off the ground are you?
As for the purlin? I'm lost, I thought those were used in roofs.
my5sons is offline   Reply With Quote
Old 11-02-2008, 10:53 PM   #3
Rewards Points: 150
This thread is useless without pics. LOL. I would like to see this. Either you have your terms mixed up or you have a liability on your hands. Either way pics please.
James Con is offline   Reply With Quote
Old 11-02-2008, 11:02 PM   #4
What should I do?
take it apart save your lumber and rebuild to code.The joist should be 16 on center. Heres how you start the layout the first measurement should 15 1/4 and 16"after that which will give you 16 OC.The 5/4 is better to use than the 2x4s or 2x6s it will hold up better I think it's planed smoother.But if you have the 2x6 you can use them, I would say treat it as soon as possible.Use joist hangers and harricane ties is your jiost rest on a beam if you have a beam use 2 1/2" carriage where it attaches to your 4x4s or whatever you are using for colums regards Rob
super carpenter Rob is offline   Reply With Quote
Old 11-02-2008, 11:23 PM   #5
Decks have to meet the same weight bearing specs as any floor in the house. This includes spans and sq ft loads.
There is no such thing as 34" centers. Even at 24" centers I would be concerned about stability if there were a lot of people on the deck. And 24" centers are used sometimes for floors.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-03-2008, 12:20 AM   #6
here are pics of the perimeter before I hung the joists
Old 11-03-2008, 12:38 AM   #7
Here are pics of the frame after hanging joists/cross braces (thought they were called purlins) and after laying decking...
Did this all myself, no help so I am dreading pulling it all apart.
You can see all connections to posts/footer use 3/8x6 Lag screws, no carriage bolts. Also all decking uses 2.5" stainless screws, no nails.
I could put beams under the joists fairly easily I think, but that wouldn't help the 33-1/4" span between joists. If I hadn't put crossbraces I could probably get under there and add more joists. would be tight though.
BTW - I used 2x6 over 5/4 because it is cheaper (I had a $1000 budget which is blown now that I am roofing it) and 1.5 inch logically would offer more rigidity than 1.25 inch, I would think. I know they are planed smoother but these are not bad at all.
Old 11-03-2008, 01:06 AM   #8
Rewards Points: 150
This might be a silly question but are the joist treated wood. It's kinda hard to see the color. Also if you are not putting any kind of lateral bracing like Rated sheating or let in braces you might want to reconsider the roofing. On second thought I would not put a roof over this. You might get away with the deck the way it is, being it is low to the ground (not far to fall) which is why you probably didn't need an inspection from your town. But nix the roof. Maybe get a portable popup canopy to cover it. But make no mistake about it this is not the right way to do a deck, even at the bare min. code. Take the roof warning serious!!!!!!!
Here's a good website for plans and different ways to build. http://www.decks.com/
Old 11-03-2008, 09:00 AM   #9
Well, interesting is all I can say.
Don't get me wrong, you have a nice looking deck and did a good job for what you know and were told.
Here is where the deck falls short.
The joist spacing is too far apart. The joists are spanning too far for their size. They should be at least 2x8's or 2x10's at 16 inch centers.
The good news is that you have lots of 4x4 supports, just not in the right places.
From where I sit you can save your deck without tearing it down.
The first thing is that I would add some more joists to fill in the gaps. Use joist hangers to secure them. You will have to knock out the cross pieces in the way now.
Then get a 4x6 pt and run it down the middle perpendicular to the joists and use pier blocks to rest it on and make sure it is up tight against the joists.
While this may not look pretty from underneath and is far from accepted building practices it will hold up your deck and make it safe for years to come.
You can do this all from underneath without tearing it down.
Old 11-03-2008, 09:53 AM   #10
Thanks for the compliment, this is the first time I have even built something like this.
I will pull the decking this weekend and add the joists/4x6 beam. Do I need to put cross braces back in? Also, no the joists are not PT, just #2
Also, the roof will be PolyCarb sheets from Suntuf, what kind of bracing do I need for that? Suntuf recommends max 36" center on the rafters, I was going to go 30"
Old 11-03-2008, 10:00 AM   #11
Rewards Points: 93
That looks great. However, it is all bittersweet. Your deck isn't built with pressure treated lumber. I'd be surprised if it lasts more than 3 years - 5 years before it falls in.
You are wasting your time and money now. I would leave the deck the way it is, don't install a roof, and wait for it to rot and start all over again with pressure treated in 2 years. If you get some more money again, I'd start tearing it up and do it all over again.
I'm no expert, but just wanted to comment.
Old 11-03-2008, 10:00 AM   #12
Go with what they recommend. The reason is that they are sized so they will fit exactly on 36" centers.
Is there danger of snow load? Or high winds?
If so then there needs to be some consideration for that.
Old 11-03-2008, 10:14 AM   #13
Thanks for the comment, I wish everone were as helpful as you... Wait for it to rot? After all the hard work? untreated wood lasts many years here, and I coat it with linseed oil. That fence in the background, 15 years old according to my neighbor who has been there that long, no rot, just discoloring.
Old 11-03-2008, 10:18 AM   #14
They recommend 24" for vinyl sheets and 36" for polycarb
We rarely get 2" of snow per year here, so snow load is not likely
We do get 60 mph winds occasionally
Old 11-03-2008, 10:24 AM   #15
Rewards Points: 93
I'm just guessing, but you won't be able to coat the wood underneath the deck will you? That will be your problem. There was a study done at a college that listed pine as about 10 years for cross bracing, 5 years for L-joints and post rails.
If you used Douglas Fir, the estimates are much better.
So I'm just guessing here, but I wouldn't feel comfortable with it. Not to mention, every code I know of lists PT only!
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Deck Ledger To House Osb Rim Joist munson_11 Building & Construction 7 04-19-2008 12:41 PM
Connecting rim joist to deck ovahimba Building & Construction 5 01-19-2008 08:33 AM
