Deck Joist Cut Too Short - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 05:18 PM   #1
Novice here... managed to cut one of the joists for our deck about 1/2" short on one end, about 1/4" short on the other (these joists are about 12', for a deck that's 10' x 12'). Both ends are resting on hangers. On the shorter side, there is still 1.5" of joist being supported by the hanger. Do I need to replace this one? Thanks very much!
Artemis2007 is offline   Reply With Quote
Old 07-13-2012, 07:43 PM   #2
Rewards Points: 2,212
Yes you do
I was just going to say Yes but it told me the message was to short!
mae-ling is offline   Reply With Quote
Old 07-13-2012, 08:48 PM   #3
Davejss's Avatar
Rewards Points: 772
Wait. It's 1/2" short on one end and 1/4" short on the other? Wouldn't that just make it 3/4" short regardless of which end? My head hurts.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
oh'mike (07-13-2012)
Old 07-13-2012, 11:40 PM   #4
Nope it would be 3/8" on both ends
Old 07-14-2012, 05:59 AM   #5
Too Short? Cut it Again!
Old carpentry joke is to measure twice, cut carefully, but don't panic if you cut something too short. You can always just cut it off again.
I too caught that the timber was cut 1/2" short on one end but only 1/4" on the other.
It needs to be replaced. Sorry!
Old 07-14-2012, 12:46 PM   #6
Rewards Points: 1,216
Go buy another board, you can always use the short one for something else you'll see.
COLDIRON is offline   Reply With Quote
Old 07-14-2012, 01:18 PM   #7
Civil Engineer
Rewards Points: 4,770
If you can drive all the required nails through the side of the bracket into the floor joist, there is no need to install a new board of the correct length. It would not hurt anything to do so of course, but the typical Simpson hanger is designed to function correctly with a board that is a little short, how short is a function of the specific hole locations on the bracket. The shear strength of the bracket is controlled by the nails connecting the bracket to the beam or rim joist, which has nothing to do with the nails driven through the bracket into the floor joist.
Daniel Holzman is online now   Reply With Quote
Loose Deck Joist Hangers: Pictures akant Building & Construction 15 06-26-2012 09:06 PM
Another rotten rim joist / deck :) blownbudget Building & Construction 1 10-05-2011 11:46 AM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 08:25 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
UGH! just realized one of my deck posts is cut too short nasdaqer Carpentry 8 06-19-2007 07:26 AM
