Deck Joist To Beam Connections - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 11:49 PM   #1
Deck joist to beam connections
I am building a deck with 2x8 joists that span two beams. The deck will be no more than 20 inches off the ground.
I know I need hangers to connect the joists to the house but is there a problem with just toe nailing the joists to the beams they are resting on. If you recommend a hanger or bracket instead what kind and why? Thanks in advance for your help.
gpolkin is offline   Reply With Quote
Old 03-17-2011, 06:34 AM   #2
Toe nailing is fine, but check local code. Simpson does make connectors for that. Unless you are in seismic territory, not needed, IMHO.
Old 03-17-2011, 08:08 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Toe-nailing is fine
Just do a nice job of it
tcleve4911 is offline   Reply With Quote
Old 03-17-2011, 04:04 PM   #4
Registered User
Rewards Points: 526
Under the 2009 Deck Code, toe-nails only if deck is attached to house, pp.7; http://www.lancova.com/deckinfo.pdf
No built-up beams on outside of posts, perimeter close-fastening end, rim joists through decking, etc.
Gary
Old 03-17-2011, 04:29 PM   #5
no more than 20" off the ground...go floating deck, way faster construction.
pjordan4477 is offline   Reply With Quote
Tags
beam , brackets , deck , hangers , joists
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Ceiling Joist Beam RWebb Building & Construction 3 11-22-2010 01:17 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Beam - staggered davis_mc Building & Construction 16 07-06-2008 05:27 PM
