-   -   Deck joist to beam connections (http://www.diychatroom.com/f19/deck-joist-beam-connections-98660/)
gpolkin 03-16-2011 11:49 PM
I am building a deck with 2x8 joists that span two beams. The deck will be no more than 20 inches off the ground.
I know I need hangers to connect the joists to the house but is there a problem with just toe nailing the joists to the beams they are resting on. If you recommend a hanger or bracket instead what kind and why? Thanks in advance for your help.
Just Bill 03-17-2011 06:34 AM
Toe nailing is fine, but check local code. Simpson does make connectors for that. Unless you are in seismic territory, not needed, IMHO.
tcleve4911 03-17-2011 08:08 AM
Toe-nailing is fine
Just do a nice job of it
http://i172.photobucket.com/albums/w...process009.jpg
Gary in WA 03-17-2011 04:04 PM
Under the 2009 Deck Code, toe-nails only if deck is attached to house, pp.7; http://www.lancova.com/deckinfo.pdf
No built-up beams on outside of posts, perimeter close-fastening end, rim joists through decking, etc.
Gary
pjordan4477 03-17-2011 04:29 PM
no more than 20" off the ground...go floating deck, way faster construction.
