Deck Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 07:29 AM   #1
MHG
Deck installation
Can anyone help me with expected cost for a typical deck? Is there a sqft factor that can be used to help determine how large we want to consider before even calling contractors? We realize that height, design and material choices will make difference, just looking for ball park treated lumber deck?
Thanks,
MHG is offline   Reply With Quote
Old 03-08-2008, 09:28 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Deck installation
Prices vary be region greatly. Property layout, grade, structural requirements, and incedentals also factor in, among other things.
Just call some local contractors.
- Build Well -
Old 03-08-2008, 10:10 AM   #3
Rewards Points: 5,326
Deck installation
I did a 525 sq ft. deck in Queens, NY for a customer 4 years ago as part of a kitchen bath addition. It was a single level deck on a fairly level lot. Pressure treated 5/4x6" decking with metal balusters and one 5 step staircase and it ran about $12k. But as Atlantic said, conditions, deck specs and your location will determine actual costs.
Before calling any contractors, sit down and do some research on what you want, possible alternate scenarios and deck sizes so you can ask all the questions you need to.
It would help with the estimates if you came up with a specification list that all the contractors would get so they are all bidding on the same thing.
You should know where the frost line is in your area. Ask questions that require specific answers, so you can eliminate the uninformed early on.
It will probably require a permit unless you're in the boonies somewhere.
Ron
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
