Deck Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 03:23 PM   #1
Deck Help
Im in the process of adding a deck to my newly purchased home. Its only going to be approx. 15 inches off the ground. Can i just use piers? Its going to be 20 x 14. Any info will be greatly appreciated!!!
pwat300 is offline   Reply With Quote
Old 06-27-2013, 04:02 PM   #2
Devil Dog
handyman_20772's Avatar
Rewards Points: 77
First before I give my opinion, check with your local building department and see what you can legally build and what permits are required and whether you can use deck piers or if footings will need to be dug.
handyman_20772 is offline   Reply With Quote
Old 06-29-2013, 08:09 AM   #3
roofingquotes's Avatar
Same goes for me.
roofingquotes is offline   Reply With Quote
Old 06-29-2013, 08:29 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
The main factors are the size of the deck and whether it is attached to the dwelling. Also are you located in a frost protected area.
A call to your building official will provide the answer to your question without guessing.
With that said decks installed at or near grade tend to have issues with the joists twisting. This is due to the fact wood absorbs moisture causing it to expand. The top of the joist is exposed to sunlight which causes it to shrink. One side shrinks the other expands. If it were me I'd go with a nice patio, but it is your project.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-29-2013, 08:56 AM   #5
Too Short? Cut it Again!
You might think about updating your profile with basic geographic location.
In some locales, decks not attached to the house are free game and beyond the pervue of you building department. More responsible places do bring them under code and inspection. I am not sure whether you can get away with just simple piers as deck support or not.
Do heed the advice about low decks. 15" to the surface leaves your deck joist structure just 6" from the ground. Why not consider other option like concrete finished by an artisan. Maintenance will be lower than a wood deck and nicely done one can have much more wow factor. Not my fave concrete look but for example to help you explore.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
