Old 04-17-2007, 08:05 PM   #1
Deck Height w/out step
I'm putting a new deck off the back of my house. It will be surrounded by existing concrete side walks. My question is how high can the deck be without railing or a step down. Right now the heights vary between 15" in a corner near the house to a low of 8" on the front of the deck. I can simply put two different steps down in a two areas, but I prefer no steps if possible. I could also lower the whole deck and put a landing step on the deck where you exit the house, but I'm not sure that will work. Any thoughts or opinions would be appreciated.
DLP600 is offline   Reply With Quote
Old 04-17-2007, 08:44 PM   #2
Don't know the height requirements in your area but I would be amazed if you need railing for a deck only 15 inches off the ground.I have never seen or heard of a place that this would not be acceptable.
warnerww is offline   Reply With Quote
Old 04-17-2007, 08:57 PM   #3
Darylh's Avatar
24 inches up here, and I also agree I dought you would need a railing at only 15 inches. As far as a step goes you have 8 inches at the other end which would be fine to get up and down from if your comfortable with it. If it was mine I would put steps ( or even a ramp) near the house just for convenience.
Darylh is offline   Reply With Quote
Old 04-17-2007, 08:57 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I believe that the IBC or ICC code is 30" from grade level to the deck surface.
You might also wish to consult with your local building dept. They will require that you pull a permit for such a project. Speak to them about what they require in terms of your design.
The height of the your deck will be greatly affected by:
The 'size' of your deck, your landscaping, your entry onto the deck from your home, the design that you have in mind, the materials to be used, etc. All these and more will dictate the arrangement and the requirements of your subframe for your deck. The larger the deck is, the wider the joists and the supporting members are = (this equals) more height required for the deck - from grade level.
- Build Well -
Old 04-19-2007, 12:34 PM   #5
I would put some sort of barricade at the 15" height. It could be a bench along that section on the deck. Or a traditional railing if you don't want to take up an area on the deck. Falling backward off the deck ,especially if an older person, will result in an injury. You know, Aunt Hilda, after a few beers...
Ron
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Part 1 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 2 - Learn how to adjust the guitar string action to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
In this segment we are going to talk about how to get hot tubs into difficult places. Most people think that because a spa is wide, they can't get it into their backyard. But a spa is typically transported on a dolly and you flip it on the side and the... Read More »
Part 2 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck - beam to post connection (??) brocasArea001 Carpentry 17 06-26-2007 10:54 AM
Deck Railings econdave Building & Construction 10 07-11-2006 09:26 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
