Deck On Garage Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 08:55 AM   #1
Deck on Garage roof
I am going to be building a little garage on the front of my place and was thinking about putting a deck over it. I currently have a deck and am not sure how to build a garage underneath and be able to roof it so then I thought about putting a flat roof on the garage and building a deck on the roof or using the roof as a deck. Any thoughts on a flat roof for the garage and putting a deck on or using the roof as a deck?
billybarty is offline   Reply With Quote
Old 02-26-2008, 01:29 PM   #2
Rewards Points: 150
Our old house had a garage on the back with a flat deck on top. When we bought it, you couldn't walk on the deck due to the water damage (quick drop into the garage). We re-built it. We ended up with a fiberglass type of decking material with a textured surface for traction. This was a number of years ago, but I recall the decking guy installing it like fiberglass (resin, sheets of glass, more resin) sealing right up to the metal drip edges. I don't recall what the warranty was, but I'm guessing a few years. I remember being told that that a flat walking deck over a structure is a "demanding application" that takes some skill, effort and maintenance to ensure no water penetration to the lower level. It looked great. I recall being told my a few people that this was the best option as opposed to roofing and then installing a deck above the roofing, but I don't remember the pros / cons.
steve1234 is offline   Reply With Quote
Old 02-26-2008, 04:33 PM   #3
I currently have the deck and could re-use it and just build the garage underneath but I don't know how I would put the roof on. I plan on using steel roofing but I have to figure how to attach the rafters and steel. I was thinking I could possibly just build one wall higher than the next and build a lean-to style of roof on the ground and then lift it and attach it. Building a pitched roof on the ground and lifting and attaching it, i'm not sure how it could be done. it won't be a big garage, about 16 x 16.
garage roof leak Chicago Bill Roofing/Siding 8 05-05-2009 01:07 PM
Framing a garage roof -Advice please 6n165 Building & Construction 1 01-02-2008 08:43 AM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 07:44 AM
