-   -   deck with future in mind (http://www.diychatroom.com/f19/deck-future-mind-146293/)
mav375 06-07-2012 09:06 AM
I want to design and install a deck, and then at a later time, put a 3 season porch on part of it. I would like the floor of this the enclosed porch to have interior wood flooring. Can I install this flooring directly to exterior decking when time comes? Any concerns or suggestion would be awesome.
Mac
GBrackins 06-07-2012 10:31 AM
I'm not sure what you are describing ......
a porch is a partially enclosed structure with a roof. Typically open on three sides.
You say three season porch so I'm not sure if you are meaning a porch, or if you are describing an enclosed room that would only be used in the spring, summer and fall. It may contain lots of windows.
mav375 06-07-2012 08:52 PM
Yes, then, a fully enclosed porch, with windows, screen. I don't want just a deck floor at that point. I will install vap barrier under deck with insuation below, then place the wood flooring.
joecaption 06-07-2012 08:57 PM
It would be far better to remove the decking when your ready to enclose the room.
Pressure treated decking is going to to cup and bow, pressure treated anything needs ACQ approved fastners, if not there just going to corrode off shortly.
wkearney99 06-09-2012 12:19 PM
And make sure the structure is engineered as it would have to be to support the added materials. Windows are heavy and that'd put a lot more load on it. That and there's the risk of added weight from more furniture and people.
