Deck Framing - Beams On Top Of Footing (not Enough Space For Post) - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 09:20 PM   #16
Originally Posted by GBR in WA View Post
Notch with no sister: http://arch.umd.edu/Tech/Structural_..._Guide_A11.pdf
Be safe, Gary
Gary, I tried your link and it failed to connect. Is it the link or is it me?
Old 06-01-2010, 08:34 PM   #17
Registered User
Rewards Points: 4,894
Sorry, mine stopped too. I'll need to find a replacement...... Meanwhile, page #32: http://books.google.com/books?id=iwS...num=3#PPA32,M1
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 06-01-2010, 08:51 PM   #18
Be safe, Gary
Thanks Gary! I'm thinking after reading about notching, that it would OK to notch the joists but not OK to notch the beam.
Am I correct in this assumption ?
Old 06-02-2010, 09:03 PM   #19
Registered User
In this case the OP is doubling joists for a built-up beam, so I would think, yes.
Only 1/10th on a glue-lam of the tension side (bottom) : ttp://www.rosboro.com/pdfs/S560E.pdf
Again, drill a hole at the horizontal/vertical cut: http://www.finehomebuilding.com/PDF/Free/021184090.pdf
The answer is: http://books.google.com/books?id=Q86...ed=0CDMQ6AEwCA
Perhaps an Engineer would share their thoughts, especially if I'm wrong.......
Be safe, Gary
Tags
beams , deck , footing , low level , post
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
flat roof under deck??? Jeremy Hillary Boob, PhD Roofing/Siding 3 05-05-2009 08:20 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
"Wagging in" 2x8 beams for my deck? deckman Carpentry 5 08-08-2007 11:35 PM
