Deck - Framing Around A Bay Window - House Rim Joist Changes Levels? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 07:22 PM   #1
Deck - Framing around a bay window - house rim joist changes levels?
Since code does not allow a ledger board to be attached to a bay window cantilevering out from the house, I planned on framing around the window as shown in Fig. 35 at http://www.lancova.com/deckinfo.pdf. However, in my case, the interior floor level of my house drops immediately on one side of the bay window (slightly sunken family room), and therefore the house rim joist are at different levels on either side of the bay window. How can I frame around this bay window? Any help? I don't feel comfortable trying to find the wall studs and tying into them. thanks
Since the house rim joists are at different levels, I planned on the deck being two levels following the level of the house rim joist.
jkwaldron is offline   Reply With Quote
Old 10-16-2011, 10:11 PM   #2
robertcdf's Avatar
An engineer can design an option that would allow you to attach to a cantilever, we do it on a regular basis. I also attach to wall studs on occasion with no issues. It is of course important to make sure you are going into the center of the stud with ledgerloks (since they are 1/4" dia) and that you predrill straight so you don't get off track and go through the side of the studs.
robertcdf is offline   Reply With Quote
Old 10-16-2011, 11:36 PM   #3
Registered User
Rewards Points: 526
I might add to use an adjustable electrical live-wire locator to find exactly where the wire runs are (usually at knee-level) so not to drill/lag the wire through stud hole. Stud locator will find centers at drywall, transfer measurements to exterior. Drill small diameter pilot hole first, follow with proper size bit for larger lag bolts.
And, welcome to the forum!
Gary
Old 10-17-2011, 08:24 PM   #4
Thanks GBR and robertcdf.....I suppose I could always go with a freestanding deck also but I really don't want to go that way.
Deck footers near house drjohnson Building & Construction 10 04-13-2011 11:43 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 08:34 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
