Deck Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 07:59 PM   #1
JAL
deck framing
Can I span 14' using 2x10 pt wood 16' oc?
JAL is offline   Reply With Quote
Old 05-20-2010, 08:06 PM   #2
According to span charts on this site you can
http://www.decks.com/articles.aspx?articleid=41
Old 05-20-2010, 08:47 PM   #3
Registered User
Rewards Points: 526
Only if Southern Pine, as Dave's site said. Any of the seven other species: http://www.anthonyforest.com/pdfs/DCA6.pdf
Most Building Departments are using this for spans, footings, ledgers, fasteners, bracing, etc., keep in mind this is minimum required code for safety, from the wood supplier.
Be safe, Gary
Old 05-20-2010, 09:11 PM   #4
I should have mentioned that I probably would not span 14'
I only have 6-7' between my beams & my joists are 12" OC
Its rock solid & was not that much more $$ to build it sturdier
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Should I treat the existing framing for my deck? renoet General DIY Discussions 9 05-08-2009 01:09 AM
Framing a whirlpool deck! MikeVila Carpentry 14 12-18-2008 12:43 AM
Tub Deck Framing FlyBoyd Carpentry 3 10-18-2008 11:32 PM
