-   -   deck framing (http://www.diychatroom.com/f19/deck-framing-71716/)
JAL 05-20-2010 07:59 PM
deck framing
Can I span 14' using 2x10 pt wood 16' oc?
Scuba_Dave 05-20-2010 08:06 PM
According to span charts on this site you can
http://www.decks.com/articles.aspx?articleid=41
Gary in WA 05-20-2010 08:47 PM
Only if Southern Pine, as Dave's site said. Any of the seven other species: http://www.anthonyforest.com/pdfs/DCA6.pdf
Most Building Departments are using this for spans, footings, ledgers, fasteners, bracing, etc., keep in mind this is minimum required code for safety, from the wood supplier.
Be safe, Gary
Scuba_Dave 05-20-2010 09:11 PM
I should have mentioned that I probably would not span 14'
I only have 6-7' between my beams & my joists are 12" OC
Its rock solid & was not that much more $$ to build it sturdier
