Deck Footing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 11:26 AM   #1
Hi All- New to the forums. I have an 8 year old deck that seems fairly solid for the most part. I've noticed the last 2 winters, however, that part of the deck (where the stairs start) seem to rise when the ground freezes (am in MN). This part happens to be under a post which is sitting on a footing. My hunch is that the footing is not deep enough and is being pushed up with the freeze, then settles down with the thaw. Any thoughts?
I would like to remediate- do i put a temporary brace up then re-pour a deeper footing?
Thanks!
JDK1 is offline   Reply With Quote
Old 04-17-2013, 11:59 AM   #2
Rewards Points: 14,290
Got a picture?
And your right the footing was not deep enough.
Old 04-17-2013, 12:02 PM   #3
I will snap one later today and post back....
Old 04-17-2013, 08:06 PM   #4
Here are some pics- Not sure if they'll help.
Deck Footing Question-img_0832.jpg   Deck Footing Question-img_0833.jpg   Deck Footing Question-img_0834.jpg   Deck Footing Question-img_0835.jpg
Old 04-17-2013, 09:24 PM   #5
GBrackins's Avatar
Rewards Points: 2,108
it could be caused by not installing the footing below your frost depth. it could also be that the frozen ground was able to grab the side of the sonotube and force it upward. make sure to check all of your deck connections to ensure they are still tight, sometimes movement can loosen connections.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
jomama45 (04-18-2013)
Old 04-17-2013, 09:41 PM   #6
Thanks for the response- Any suggestions on how to remediate? Will going with a deeper footing prevent either one of the scenarios you mentioned? Thanks.
Old 04-17-2013, 11:40 PM   #7
Registered User
Rewards Points: 526
Page 19, Fig.34; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
42-60+"; http://www.soundfootings.com/pdf/US_...t_DepthAVG.pdf
Use gravel under the new footing for drainage; http://www.sustland.umn.edu/implemen..._footings.html
http://www.waltersforensic.com/artic.../vol1-no11.htm
Gary
Old 04-18-2013, 09:26 AM   #8
Thanks Gary- good resources...
The Following User Says Thank You to JDK1 For This Useful Post:
Gary in WA (04-18-2013)
New Footing Question Wirepuller Building & Construction 15 06-16-2012 01:00 PM
Unique deck question amcinnis1 General DIY Discussions 5 06-12-2012 09:52 PM
deck question toddj99 General DIY Discussions 5 04-24-2010 10:12 PM
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 04:36 PM
Question about maximum deck size in Delaware. Doctorsti Building & Construction 13 03-03-2009 07:21 PM
