Old 05-02-2010, 07:19 PM   #1
Deck footers--we poured concrete before depth inspection
We are building a 12LX15W deck with 3 posts. We just finished the (3) footers that were dug to 30" in depth and 16" wide and filled them all up with cement. Now we realized the big mistake we made--the building permit requires an inspection of the footer depth prior to pouring any concrete. Any way to prove it w/o ripping it all out?
Phillies34 is offline   Reply With Quote
Old 05-02-2010, 08:15 PM   #2
Mod
kwikfishron's Avatar
Call them and say what you did.
All you’ll probably have to do is dig out a side down to depth so he can see, just don’t dig below the footing.
This is were a little "polite diplomacy" can go a long way.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 05-02-2010, 08:41 PM   #3
That is what I am hoping will work, a cut out to show the depth..
Old 05-02-2010, 10:15 PM   #4
firehawkmph's Avatar
Philly,
My excavator cousins always use a steel rod with a crossbar welded on top to form a t-shape to probe for pipes in the ground, water shut off boxes, etc. You could probably make one out of a piece of 1/4" round stock. Twist it at a slight angle next to your pilings and aim for what you figure the bottom is. You should be able to feel whether or not you are hitting th concrete. Might save you digging the hole.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-03-2010, 11:27 AM   #5
Thanks for the tip Mike..
Concrete Pillars Raising Deck Ladybear Building & Construction 7 09-23-2009 04:31 PM
Deck clearance over concrete miles Building & Construction 4 09-19-2009 07:24 PM
Depth of Concrete Piers for A Deck marathonman Building & Construction 3 05-18-2009 05:22 PM
Math check on amount of concrete for poured foundation? Badfish740 Building & Construction 10 05-05-2007 07:49 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
