Old 06-04-2008, 11:59 AM   #1
Non stop DIY'er!
Deck Fascia
Almost done putting the decking down, and I want to finish off the fascia with a clean look. Since the deck is only 15 in. high, the entire front of the deck will have two steps, no railings and the fascia will be very noticable. What type of material would be best? like a 1x8 of something treated.
bajaboy1 is offline   Reply With Quote
Old 06-04-2008, 12:01 PM   #2
Non stop DIY'er!
Deck Fascia
Also, can whatever I use be glued down? With finish nails also?
Old 06-04-2008, 01:02 PM   #3
Non stop DIY'er!
Deck Fascia
Pic of what I'm talking about. Projects give me a reason to buy new power tools also!
Old 06-04-2008, 01:04 PM   #4
Non stop DIY'er!
Deck Fascia
Old 06-04-2008, 01:13 PM   #5
Non stop DIY'er!
Deck Fascia
Both ends of the deck will have privacy fence. Just the front to have steps all the way across.
Old 06-04-2008, 02:40 PM   #6
Moderator
Termite's Avatar
Deck Fascia
I usually use 1x cedar, and bring it up to the level of the walking surface. It makes a nice look, and makes decking around the posts easy.
Old 06-04-2008, 03:11 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Deck Fascia
You could do composite (Kleer,Azek, Koma)?
Example:
Alternative: Pre-Primed and painted premium 1x trim boards.
- Build Well -
Old 06-04-2008, 04:35 PM   #8
Moderator
Termite's Avatar
Deck Fascia
Nice new miter saw by the way. I have that same miter saw stand and really like it.
Old 06-04-2008, 04:54 PM   #9
Deck Fascia
We have one of those Ridgid sliding compound saws too. That things a behemoth. It survived a 15' foot fall off a pumpjack setup. Needed a new handle.
(We use TracRac miter-saw stands)
- Build Well -
Old 06-04-2008, 07:30 PM   #10
BUILDER / REMODELING CONT
buletbob's Avatar
Deck Fascia
I used cedar for many years until they came out with Koma And Azek trim board, the home owners would complain about the carpenter Bee's drilling holes in the boards. The composite boards look great and don't have to be painted. I personally like the decking over hanging the fascia, this way you don't see the dirt in the seams after a while.
Old 06-06-2008, 09:03 AM   #11
Non stop DIY'er!
Deck Fascia
Little late posting. Bad weather here, shut down my business for a day, not good.
Anyway, I did see some 1x 8's treated, but not sure if I can get long enough pieces. One needs to be a 16' to keep it one long piece. All HD had was 8'. Haven't researched yet.
On the overhang, not sure which to do, let the decking overhang the 1x or visa verca. Like I said, it will all be very noticable since steps will run the entire front.
Old 06-06-2008, 09:26 AM   #12
Non stop DIY'er!
Deck Fascia
Yea, the saw and stand are nice. When I start a project, I include the new tools in the estimate so my little woman never notices.
Old 06-08-2008, 07:15 AM   #13
Non stop DIY'er!
Deck Fascia
Got a friend in the woodworking biz, gonna plane down two 2x10x16's to about 3/4" for me for the fascia.
What type of glue to use on treated lumber for outdoors?
Should I notch the wood? Read that somewhere to keep it from cupping?
Old 06-08-2008, 07:42 AM   #14
Deck Fascia
Generally, there is no need to glue the trim boards. If you want to, you could use either construction adhesive (Liq. Nail) or Polyurethane glue (Gorilla Glue).
That shouldn't be necessary.
- Build Well -
Old 06-09-2008, 08:15 AM   #15
Deck Fascia
I actually brought my 1X up flush with the decking as opposed to running the decking out another 1 1/2 inches and butting the fascia up under it. I like it.
tigerbalm2424 is offline   Reply With Quote
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
