Deck Cantilever Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 02:32 PM   #1
Rewards Points: 154
I'm building a deck that wraps around the house. I changed the plans slightly which resulted in reorienting one of the beams. Here are some photos of the corner and my planned fix. If the inspector has a problem with it I can always put metal braces under the cantilever which I'm sure would make it strong enough, it just wouldn't look as nice.
Anyone see any engineering or code problems?
Deck Cantilever Problem-img_6197.jpg   Deck Cantilever Problem-img_6193.jpg   Deck Cantilever Problem-img_6190.jpg   Deck Cantilever Problem-cantilever.jpg
ovahimba is offline   Reply With Quote
Old 02-06-2010, 04:12 PM   #2
Rewards Points: 5,336
I would remove the 2x10 over the support beam and run 2x10 out riggers to the outer rim joist. I'd also double up the rim joist going around the deck.
I'd run the issue past the inspector before doing it as there might be earthquake considerations.
Ron
Old 02-06-2010, 05:59 PM   #3
Registered User
Rewards Points: 4,934
Your cantilevered joists exceed the required joist length on a few of the shorter ones: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Page 7, option 2 or 3, on all joist/beam connections. Your post height may exceed the limit, hard to say. Watch the span table as decks are not rated at house floor spans any longer.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 02-08-2010, 11:08 AM   #4
Rewards Points: 154
Thanks for the feedback. It is kind of a puzzle to line up boards to catch as much of the support beam as possible. Either way I am violating the span/cantilever ratio on some of the short joists. Like I said if the inspector notices I can always add bracing hardware.
My contractor friend told me to keep a couple potted plants up there so no one can ever stand on that corner of the deck.
Old 02-08-2010, 11:22 AM   #5
Military Mom of 4
Snav's Avatar
Please be responsible with your work - you might be held responsible for any accidents that happen in the future due to failed supports. I, personally, wouldn't trust that someone wouldn't hound you to pieces and gut your future over any little thing happening.
If I were you I'd consider doubling up the supports in that corner one way or another - metal bracing if necessary (you can build a thin wood box to hide it) - or run some alternate-pattern support that will fall on that support beam and fill that gap. (They would run left - right in your first photo over that support beam).
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-08-2010, 02:01 PM   #6
Rewards Points: 154
Sorry for the last comment. I am taking it seriously which is why I posted here. I don't have a lot of confidence in the local building department for these details.
The problem with running boards right/left is there will an unsupported space above where the support beams meet(as viewed on the diagram).
In another part of the deck, I sandwiched some 4x blocking with 5/8" threaded rod and it felt really solid. I could add another line of blocking onto the plan shown on the diagram.
My ultimate plan, whatever design I choose, is to stack 5 or more bags of concrete (50lbs/sq/ft) at the corner to see if I get any significant sag. If there is any sag the braces go in.
Old 02-08-2010, 02:22 PM   #7
Military Mom of 4
Snav's Avatar
Is this something like what you did at the other spot?
Double up the framework that makes the corner - using cut-to-fit slats of the same size, clamps, wood glue and screws - set it and forget it.
Your deck will be awesome, btw - I've always wanted a wrap-around but to have a wrap around you have to have a decent house, first!
Old 02-08-2010, 03:59 PM   #8
jlhaslip's Avatar
Rewards Points: 396
I would think that the framing would need to be changed.
This image shows two different layouts. It would depend on the deck board placement to figure out which one I used.
There might also be blocking requirements re: deck boards so the joints are all fully supported.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-08-2010, 06:04 PM   #9
Military Mom of 4
Snav's Avatar
Yeah, JL's plan is a good one - full support all the way around.
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 04:47 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Confusion Viking2008 General DIY Discussions 4 07-10-2008 04:41 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
deck drainage problem darsunt Building & Construction 4 12-30-2006 01:45 PM
