Old 05-01-2012, 09:44 PM   #1
Deck built over cement step
We are planning a new deck. The problem is there is a solid cement step in the way. To remove it would require a bobcat tractor with a jack hammer to break it into pieces.
If the deck was build over the step would that violate codes.
Would this cause construction problems?
Shurl is offline   Reply With Quote
Old 05-01-2012, 10:15 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
it violate codes, you just have to allow for it being in the way of the joists by notching the joists but ensuring they dont go anywhere by shimming under them on the highest step
woodworkbykirk is offline   Reply With Quote
flat cement roof naturallight Roofing 7 05-11-2012 10:25 PM
Leveling a deck denemante Building & Construction 10 08-24-2010 09:11 AM
The deck I built Lulimet Project Showcase 5 08-22-2010 09:49 PM
Movement of cement pool deck around inground pool sgagnier Landscaping & Lawn Care 1 07-05-2010 01:31 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
