Deck Building Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 08:55 PM   #1
Deck building question
I'm going to be replacing our front porch/deck soon and I cannot find a any details about what I need to do in regards to support.
I have a book and have done lots of reading online but any deck example always shows one side anchored to the house, and the opposite side supported by a beam.
I'm going to be anchoring two sides to the house and a beam just doesn't seem to get me more support than simply having two posts using concrete piers supporting the outside corner that is unsupported.
Any insight?
coray is offline   Reply With Quote
Old 05-12-2010, 09:14 PM   #2
a pic says a thousand words, if you could post some pics that would help. As well a better description would be helpful. ie: length, width, height.
I would use a corner pier and a center pier if longer than an 7 foot span.
william duffer is offline   Reply With Quote
Old 05-12-2010, 09:30 PM   #3
General Contractor
So your deck will be on an inside corner of the building? If that's the case then you will need a beam with one end of it attached to the house. You can use either a beam hanger or a beam pocket to make that connection. The other end of the beam would be supported by a post.
Decks always need a beam to support the ends of the joists, you can't just throw a post under the deck joists. Well you can but it's not correct, wouldn't pass a building inspection anyway.
KennMacMoragh is offline   Reply With Quote
building a deck over septic weepers boddah Building & Construction 10 11-01-2010 07:09 PM
A couple of Deck railing and privacy fence/screen question EightmanVT Building & Construction 9 06-01-2010 08:03 PM
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 04:36 PM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 04:26 PM
Help - Question on deck rebuild? missin44 Building & Construction 9 08-22-2008 11:21 AM
