Deck Building Mk II - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 03:00 PM   #1
Rewards Points: 119
Deck Building Mk II
Hi All,
In the process of shopping around to get my existing deck waterproofed (by replacing the top surface with vinyl / aluminum etc), I have realized that there are a few issues with my deck structure that would also need fixing.
My house is two floors with a finished daylight basement and a concrete patio. The current deck is merely attached with joist hangers nailed into the rim joist. Yeah, I know, so it looks like a total demo and redo.
The problems really start when I try and figure out how to frame the deck structure. Because of the cantilevered structure I can't attach the deck to the house in that area, and it is too wide to frame around. I would really like to not have a free standing deck because then I have to include angled bracing which would interfere with my view, whereas I think that if the structure is attached to the house I can use the fact that I will have a 3/4 ply subfloor (for the waterproof surface) to resist the lateral loads.
Before I suck it up and approach a structural engineer, is there any immediately obvious way around the stoopid cantilevered section. If it helps, the house plans were originally drawn up with only a small deck outside the raised patio doors which stopped at the edge of the cantilevered section.
The pictures below are an attempt to show the rear wall of the house with and without the deck.
Thanks in advance for any help!
Cheers
Chris
spiragui is offline   Reply With Quote
Old 02-20-2013, 03:14 PM   #2
Rewards Points: 14,026
Just a real picture of the house now would make it real easy to figure out.
Sure hope you do not plan on have a deck level with any door openings like it's shown in the picture.You need a minimum of 4", more would be even better.
Old 02-20-2013, 03:20 PM   #3
Rewards Points: 119
Joe,
That's just my poor drawing. Lowering the deck is another one of the reasons the deck would be demo'd as the total floor height will increase over the existing deck.
I'm trying to find a picture...
Chris
Old 02-20-2013, 03:38 PM   #4
Rewards Points: 119
Ta da!
Old 02-20-2013, 04:26 PM   #5
robertcdf's Avatar
Another option.... that doesn't really work anyways because you are trying to drop the deck... You can remove the rim of the cantilever and rest the deck joists on the wall, then fill in with blocking.
Option 2: drop the deck BELOW the cantilever and hang the ledger UNDER the cantilever (attaching to wall studs) and then build a step outside the door.
My personal option is to use engineering to attach to the cantilever, we do this ~8-10 times a year.
robertcdf is offline   Reply With Quote
Old 02-20-2013, 04:33 PM   #6
Rewards Points: 119
Robert,
Dropping the deck height probably won't work unfortunately as it would drop the deck joists below the top of the door.
So with careful design it is possible to attach to the cantilevered structure, on the proviso that the cantilever (henceforth known as CL to save my fingertips) structure meets certain requirements?
I was thinking of cutting a hole into the soffit under the CL to see how it was framed. The other problem is that there are two fart-fan vents between the joists that are currently attached to the CL, but maybe they could be rerouted to point down through the soffit?
Cheers
Chris
Old 02-20-2013, 05:49 PM   #7
robertcdf's Avatar
You must have a low ceiling basement, or a tall door with a short header. Usually the wall is 8' with a 6'8" door leaving you 1'4" of room, likely your deck is 2x10's which is 9.25".
Old 02-20-2013, 08:41 PM   #8
Rewards Points: 119
Just been out and measured it and it's just over 12". I would definitely prefer attaching to the cantilever if possible.
Can I just use the tripled trimmer / header approach and attach the header to the cantilever?
Thanks!
Chris
Old 02-20-2013, 10:04 PM   #9
robertcdf's Avatar
Thanks!
Chris
You can do whatever you can get the building department or an engineer to approve. Personally I'd talk to the engineer, if you get a smart one it's not as bad as you might think.
The Following User Says Thank You to robertcdf For This Useful Post:
spiragui (02-21-2013)
Building rooftop deck dwt Building & Construction 4 07-22-2011 03:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 08:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 04:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
