Old 09-26-2012, 07:32 AM   #1
Frustrated DIYer
Deck building checklist
Hi Everyone,
Does anyone have a ready made checklist for deck building. I'm building it myself, and I want to minimize the mistakes that i might and maybe i will commit. So i thought of a checklist would really help.
Are there other things you can recommend to make the experience worthwhile?
Obn2012_Aus is offline   Reply With Quote
Old 09-26-2012, 08:46 AM   #2
sdsester's Avatar
Every deck is different and there are so many variables depending on what you are trying to do. I would go to your library and look over some of the books on decks until you find one close to what you want to accomplish. They will have material and checklists.
Alternatively, look online for free or inexpensive deck designs. There is some inexpensive deck design software out there ($40US) that does a fairly decent job of building take-off lists and things as you design your deck.
sdsester is offline   Reply With Quote
Old 09-26-2012, 08:56 AM   #3
Download this document: www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
Old 09-26-2012, 09:26 AM   #4
AHH, SPANS!!!
I was recently looking at a construction book from the 80's and everything they recommended is far from code now a days. If the year of publication is from long ago consider not using the advice presented within the pages, only as a reference that will need major refining...
hand drive is offline   Reply With Quote
Old 09-26-2012, 11:02 AM   #5
GBrackins's Avatar
as md2 suggested above, download the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide" and follow it. It is based upon the 2009 International Residential Code, the basis for most local and state building codes. It provides you with the information to construct a code compliant deck without the need for engineering. Now if you want to vary from the requirements of the guide then you would need (in most jurisdictions, yours may be different) to hire a professional engineer to design and demonstrate compliance with the building code.
if you have not already done so, I would highly recommend contacting your local building department and finding out if a permit is needed for your deck, and what drawings if any are needed. Don't want to get a "Stop Order" issued by the building department. The cost of the permit really goes up at that point as a penalty for working without a permit, and they could require you to remove what you had constructed without a permit. Just a suggestion ......
Post back with any questions.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 09-26-2012, 03:12 PM   #6
are you building your deck in Philippines or in the US?
allthumbsdiy is offline   Reply With Quote
Old 09-26-2012, 03:15 PM   #7
GBrackins's Avatar
good point thumbs! I'm not used to checking as it seems most newbie's do not enter their location .....
Gary
Old 09-26-2012, 11:43 PM   #8
Frustrated DIYer
No I'm not building them at Philippines, it's my current location. I'm planning to build it when I get back home. Thanks for the advice guys it really helped me a lot. I should definitely consider the permits required.
Old 09-26-2012, 11:47 PM   #9
Call Miss Utility before digging.
Building rooftop deck dwt Building & Construction 4 07-22-2011 04:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
