Old 04-18-2009, 10:00 PM   #1
Deck building
I want to build my first deck. The picture below depicts what I have to work with. A 10ft long, 7 inches wide ledger board attached to the house. I cannot attach another ledger board to the other half of the house because the basement has a finished ceiling. From ground level to the top of the ledger is approximately 1ft. I have a gravel pad that spans 20ft, the width of the house, and is 123 inches long. I would like to build a deck that is the size of the gravel pad.
I need some advice on where to start regarding how to dig piles, should I contract this part out and just do the attaching and cutting? I'm not sure what the best span between joists would be for this size deck or if I should overhang past the 123 inches, etc, etc.
I live in Alberta Canada and we go from lower than -30C in the winter and past 30C in the summer(if we're lucky).
n0c7 is offline   Reply With Quote
Old 04-18-2009, 11:08 PM   #2
Deck building
Here in Ontario our footings must be down 4 feet, so would expect that yours would be greater than this!
The use of ledger board for a deck is unwise! Its best to make it self supporting, on its own piers!
Old 04-18-2009, 11:19 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Deck building
Why can't you attach a ledger board?
My ledger is held in by lag bolts, no inside access was needed
If the ledger board is secure I see not problem with using to support a deck. Just make sure that there is plenty of support besides the ledger board
A 10x 20 deck - nice size
I dug my own holes down past/near the frost line
I hit ledge on a few holes, same as my garage foundation
But the ledge isn't moving, so the deck isn't
12" high deck isn't that high
And spanning just over 10' isn' that bad
Scuba_Dave is online now   Reply With Quote
Old 04-19-2009, 01:37 PM   #4
Deck building
How would I safely attach lag bolts if I cannot see what is behind the sheathing? I wouldn't want to drill or hit any of the lines someone may have buried in there.
Old 04-19-2009, 01:38 PM   #5
Deck building
I'm all ears, like I said I've never done this. I've seen 10ft high decks using only ledger board and I thought this was what they were for. Why wouldn't I want to use it and what would I have to do to make it self leveling?
Old 04-20-2009, 09:15 AM   #6
Not so new
12penny's Avatar
Deck building
n0c7.....really no need to worry about what is on the inside of the rim board. Max length of your bolts will only be 4" - 4.5". They will only protrude inside 1/2" or so.
A free standing deck would require at least 3 more footer holes 2' or so from the house. In this situation you may have to dig down to the house footers to find virgin soil capable of supporting the weight. IMO its easiest to use a ledger.
Also replace the ledger thats there if its all split and twisted.
12penny is offline   Reply With Quote
Old 04-20-2009, 10:21 AM   #7
Deck building
Ledger boards are used because its the cheap and easy way out! Not necessarily the best!
The worst part of a ledger board is that the siding or brick veneer must be removed to allow the ledger to be fastened directly to the rim joist!
Cutting open the siding then leaves open the possibility of moisture, wind and insects getting into the building!
You will be getting organized to install some piers anyway, so a few more isn't a big thing! And you won't even have to consider touching the house.
In my area, as soon as you start work on the structure ofa house a building permit is required! Irregardless, of how large or how much the deck will cost!
Old 04-20-2009, 10:54 AM   #8
Not so new
12penny's Avatar
Deck building
[quote=Wildie;262789]Ledger boards are used because its the cheap and easy way out! Not necessarily the best!
Mr. Wildie....the attachment of ledger boards has been accepted practice for 100 years...200...perhaps more. When properly sized, attached and flashed it provides not only a very solid and stable deck anchorage but also keeps rain, wind and pests at bay. Is it less expensive and time consuming? In most cases yes it is, but that doesnt make it the cheap and easy way out. That being said, I went back to the original post and read again. I now realize that this structure is only 12" off the ground and I have to tell you that in this situation I would tend to agree with you in that free standing may be the better choice. However, that same deck, 10' above the ground, needs to be tied to the house.
Old 04-20-2009, 11:51 AM   #9
Deck building
The problem with ledger boards, and I'm talking about homeowner installed ledger boards is that they don't know how to attach them, they don't know where to attach them and they don't know how to flash them so the structure doesn't rot out from under them.
I've seem them nailed up with 10 D common nails, screwed up with drywall screws and nailed up with gutter spikes.
Free standing decks are easier(better) in that they don't compromise the house structure when they build the deck.
Ron
Old 04-20-2009, 05:28 PM   #10
Deck building
[quote=12penny;262807]
Within the last week, I just installed a ledger board on my own home. It is more than 8 feet from ground level and was necessary for this particular application.
At this height, it lends stability! Never the less, I have reservations about ledger boards for the above, stated reasons!
As you have noted, where stability isn't an issue, its easier to stay away from the building!
More On This Topic
Okay, now we are going to learn notes on our A string. The A string is the fifth string up. One, two, three, four, five. This is the open A. If you do it with your pick, you want to pick the string that's second from the top (A). We're going to have the... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
When it comes time to build a new deck for your home, the first thing you'll have to do is get rid of the old one. It might seem like a complicated task at first; but by following these instructions, you'll have the deck demolished in no time. Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Composite deck building question Big Marino Carpentry 6 12-31-2008 11:14 PM
Building Deck on top of Roof schmolze Building & Construction 0 10-26-2008 05:26 PM
Worst part of building a deck?? Ler0y Jenkins General Discussion 8 06-09-2008 04:07 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 8 12-27-2007 04:48 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
