Deck Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 11:28 AM   #1
Deck building
I went out of town while a roof was being built over my deck and came home to be unsatisfied. The deck is 10' deep by 16' wide, is footed every two sq ft, not elevated. I asked for the deck to be covered and this is what I came home to: 4x6 post on the corners, 3 ft in the ground, 2x8 headers with 2x6 joists every 20". The roof is decked with 3/8's plywood solar board, 15lb felt and a simple 30 year shingle. I am concerned that the roof needs more than just the corner posts and I don't know if its because the roof is 12' high or not but it sways. Should I put in a couple of posts for each long side (16' w) and some corner angle supports as well? Tie the sides together with 2x6 or 4x4's? The posts are solid in the ground, it is just the top that sways
rydhrd34 is offline   Reply With Quote
Old 05-08-2013, 06:58 AM   #2
Rewards Points: 13,694
Where's the picture?
We need to see what your seeing.
And of cource you got a permit and had it inspected, right?
Old 05-08-2013, 08:11 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
did you provide your builder with plans or did you leave it up to them? what did the building inspector say about the work they did?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Tags
correcting a built roof , deck roof construction
Building rooftop deck dwt Building & Construction 4 07-22-2011 03:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 08:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 04:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
