Deck Building - Building & Construction - Page 19 - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 04:03 PM   #271
Not so new
12penny's Avatar
Rewards Points: 520
Lazy inspector might let it go but wouldn't fly here.
New code specifically says no notch on railing posts.
I guess we'll see.
12penny is offline   Reply With Quote
Old 03-23-2013, 04:14 PM   #272
Rewards Points: 590
I guess we'll see.
Yep. If they have to be redone don't you think he could use an oscillating tool to notch out the decking boards a little farther to fit a full 4x4? Or maybe there's a way to make it stronger as is? Not sure why he did them like that. It looks good but seems weak. It'd probably be easier just to mount new posts outside the rim joist and replace the decking.
nikeman is offline   Reply With Quote
Old 03-23-2013, 04:17 PM   #273
Not so new
12penny's Avatar
Rewards Points: 520
I mount mine inside the rim and notch
deck boards accordingly.
The Following User Says Thank You to 12penny For This Useful Post:
joecaption (03-23-2013)
Old 03-23-2013, 04:18 PM   #274
Rewards Points: 590
How do you cover the top of the rim joist behind the post?
Old 03-23-2013, 04:26 PM   #275
Not so new
12penny's Avatar
Rewards Points: 520
With a deck board notched to go around the post.
Old 03-23-2013, 04:31 PM   #276
Rewards Points: 590
So you cut a square hole in the decking board? I have access to a jigsaw also.
Old 03-23-2013, 04:34 PM   #277
Not so new
12penny's Avatar
Rewards Points: 520
Exactly. But because the post is inboard,
deck boards go all around it.
Old 03-23-2013, 04:40 PM   #278
Rewards Points: 590
If this guy ends of quitting and I have to fix this myself or something it would prob be easier just to take the notched boards out, mount the posts outside the rim boards and just do a straight cut on the deck boards to the post. I'd like to do it inside so I can use the vinyl post bottom trim pieces I bought though. I just don't have experience with saws like that.
Old 03-23-2013, 04:45 PM   #279
Not so new
12penny's Avatar
Rewards Points: 520
Lets wait and see what the inspector says.
Old 03-23-2013, 04:48 PM   #280
Rewards Points: 590
If inspector lets it go can I make it stronger? The more I look at it the more I feel like it will break off if someone leans on it.
Old 03-23-2013, 04:54 PM   #281
Rewards Points: 590
Is there some sort of metal bracket I can attach to the notched bottom and to the rim joist?
Another angle
Old 03-23-2013, 05:21 PM   #282
Rewards Points: 590
On second thought, the 4xs are notched flush to the 2 2x12 rim boards so there's no access to the bottoms of them. They are also between 34 and 35" high and min is 36" according to code. Not sure that will matter much with the vinyl installed though.
Would it look okay if I cut end pieces off to cover behind the 4x? I'm not sure i have the skill to cut a square hole. Lol.
Old 03-23-2013, 07:22 PM   #283
AHH, SPANS!!!
Rewards Points: 1,166
if you need to cut a square hole purchase a multi tasker tool and a wood blade for it or drill corner holes big enough for a saw blade to fit through and sawz all or jig saw the rest of the hole out. for years a lot of the decks we built had notched posts ( 1 1/2" notch) and they were bolted to the rim band and the railings worked out to/with the 1 1/2" notch. never had any problems with railings not being strong enough.
hand drive is offline   Reply With Quote
Old 03-23-2013, 07:30 PM   #284
Rewards Points: 590
I read over the codes again and found this. Now I know it won't pass final inspection. I read this thing 100 times and never really noticed that part.
Old 03-23-2013, 08:38 PM   #285
Rewards Points: 590
It shouldn't be to difficult to fix this right? I'm thinking just unscrew affected decking boards, remove posts, cut new posts and mount to rim joist, put new pieces of decking down notched around new posts. Call it a day. There are 14 posts around the deck, 4 on platform, 4 more on bottom of stair cases. So I just need 11 8' 4x4s cut in half.
Building rooftop deck dwt Building & Construction 4 07-22-2011 03:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 08:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 04:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
