Deck Building - Building & Construction - Page 16 - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 11:16 AM   #226
Rewards Points: 1,214
Originally Posted by nikeman View Post
Sneak peak of progress.
Attachment 67147
Hope you crowned all them joists.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-12-2013, 11:44 AM   #227
Rewards Points: 588
Explain. Still need 1 joist on each side and then the rim joist.
nikeman is offline   Reply With Quote
Old 03-12-2013, 12:05 PM   #228
The crown is the bow or curve of the boards. The crown of the board should be at the top of the joist. They can sometimes be crowned or cupped so bad they can't be used but if you ordered the exact number of joists needed then they likely just used what was available. If who you hired knows what they're doing it should be done without question.
MisterSteve is offline   Reply With Quote
Old 03-12-2013, 12:08 PM   #229
Rewards Points: 101
I think he is just referring to placing the crown side up so that when the joists sag they eventually sag to level and not start sagging and settle even lower.
Thomas
South Jersey - Camden County
tjbingha is offline   Reply With Quote
Old 03-12-2013, 04:37 PM   #230
Rewards Points: 588
Pretty sure he did that. All the boards were pretty straight but some had some zigzag curves that I can only see when looking eye level down the board.
Old 03-13-2013, 08:27 AM   #231
AHH, SPANS!!!
Rewards Points: 1,166
best is to take a 2x4 and slide it across the framing perpendicular at mid span. start at the edge and go inward, you will bump the high ones with the 2x, you can also sight across perp to the joists mid span and see the high and low ones. nothing you can really do now but rip the top off of a high one and scab next to a low one with another joist.
hand drive is offline   Reply With Quote
Old 03-13-2013, 09:32 AM   #232
robertcdf's Avatar
Using a portable planer is the best way, however even with all that work we would come back 6 months later and it still looked like crap because PT framing lumber sucks.
robertcdf is offline   Reply With Quote
Old 03-13-2013, 09:36 AM   #233
Rewards Points: 588
I slid my 48" level across all the beams and there are 2 that are low and maybe 1 that was a slight bit higher. The rest are as level as can be. Not concerned at all.
Old 03-13-2013, 12:03 PM   #234
You should be concerned Carpenter's don't build houses without crowning. All lumber facing the same direction.
Not good enough. You might be able to crown them buy looking from the end toward the house. No crown = problems in a couple years.
Nails popping, cracking boards, roller coaster 5/4 boards, etc etc. Oh and that level thing that was described don't work because it only tells the level of a couple joists at a time , you need the whole joist layout level not just a 48".
Last edited by COLDIRON; 03-14-2013 at 07:25 AM. Reason: Remove text that didn't pertain to the topic.
Old 03-14-2013, 09:48 AM   #235
Rewards Points: 588
They are crowned. I looked down each one and its very hard to see but they all bend up ever so slightly near the middle. Looking from below from the side is a little more obvious actually.
I swear I posted this last night but its not here anymore. maybe I dreamed it.
Old 03-16-2013, 12:06 PM   #236
Rewards Points: 588
Concrete for the bottom stair posts were poured yesterday around 2:30 or so. It rained pretty good for about 20 mins around 8:30 this morning. It was enough to puddle water in the holes on top of the concrete. I estimate the concrete sat drying for about 18 hours before the rain. Think it will be okay? It feels pretty hard on top but not completely solid yet. Those post only stick out a foot or 2 above the concrete. I plan on putting more concrete on top later on in those holes to fill them up more and to put concrete under the 2x that attaches the bottom of the stringers
Old 03-17-2013, 12:32 AM   #237
Registered User
Rewards Points: 4,944
It can pour/cure underwater...
Gary
Old 03-17-2013, 11:58 AM   #238
Rewards Points: 588
Framing inspection set for tomorrow morning. Will they still come if its raining? It's supposed to rain until at least 10am and then a 40-50% chance the rest of the day and Tuesday morning. I'll be at work so hopefully they will call and give me a heads up if/before they come. We shall see.
Old 03-17-2013, 12:30 PM   #239
Not so new
12penny's Avatar
Rewards Points: 520
You don't necessarily have to be there. However,
I think your contractor should be. I try to be at all
inspections just to handle any concerns that may arise.
12penny is offline   Reply With Quote
Old 03-17-2013, 03:08 PM   #240
Rewards Points: 588
He will be there in my place. He was at the first one also but we were still digging the last hole when the inspector came. Lol
Building rooftop deck dwt Building & Construction 4 07-22-2011 04:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
