Deck Building - Building & Construction - Page 11 - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 01:22 PM   #151
Rewards Points: 588
Originally Posted by 12penny
Simpson# DTT2z. One pair on each end of deck.
One piece get nailed to inside floor joist. Other
one gets nailed to deck floor joist. 1/2" threaded
rod and nuts connect the two. Holds ledger to house.
Thanks. At least they aren't expensive.
nikeman is offline   Reply With Quote
Old 02-20-2013, 11:14 AM   #152
Rewards Points: 588
For some reason only one Home Depot anywhere near me carries these things and its about 45 mins away. They have 21 in stock while no others have any. What's up with that?
Old 02-20-2013, 11:17 AM   #153
Not so new
12penny's Avatar
Rewards Points: 520
Did you ask if you were required
to have them? Not all areas do.
12penny is offline   Reply With Quote
Old 02-20-2013, 11:22 AM   #154
Rewards Points: 588
They are required. It says I need a min of 2. It's very easy to miss but I'm sure the inspector will know.
Old 02-20-2013, 08:35 PM   #155
Rewards Points: 588
Just out of curiosity how do you install these? You just screw one to the house floor joist and the other to the deck joist? I can't find a good explanation. Home Depot has a "2 pack" but don't they work in pairs? If they don't work in pairs then I'm thinking I will buy 2 pairs anyway just for extra security. All pictures I have seen Show a long rod that connects the 2 but it doesn't look look like the Home Depot comes with any rod?
http://m.homedepot.com/p/Z-Max%20Dec...ck)/100671103/
Old 02-20-2013, 09:32 PM   #156
robertcdf's Avatar
Simpson book shows how it's done. http://www.strongtie.com/products/connectors/DTT2.asp Be sure to read all the details carefully, keep in mind that you need to tear up the flooring to nail off the joist-subfloor at 6" O.C. (and to prove to the inspector that it is).
robertcdf is offline   Reply With Quote
Old 02-21-2013, 08:12 PM   #157
Rewards Points: 588
Not sure why you say I have to tear up the flooring since I have full access to the joists from under the house. Can I just connect one to the floor joist on either side of the deck and connect them to the ledger? Would that not be the same thing preventing the ledger from pulling off the house? Just curious, I'm trying to learn so I can build my own deck on my shed later on.
Old 02-21-2013, 08:21 PM   #158
robertcdf's Avatar
You need to look closely at the details and the notes. The notes say that the SUBFLOORING needs to be nailed off at 6" O.C. to the joist that you are attaching the lateral load bracket to. There isn't a way to do that from below (without maybe an engineered design).
Old 02-22-2013, 06:49 AM   #159
Not so new
12penny's Avatar
Rewards Points: 520
The point of the lateral load device is to keep the joists and ledger from pulling away from the house. They must be attached to house floor joist.
Old 02-22-2013, 07:24 AM   #160
Rewards Points: 1,216
Originally Posted by NewHomeDIYGuy View Post
That deck looks nice, but wouldn't pass code in this county, and many for that matter. I'd double check what your code allows (assuming you have a building code) before building anything. Not sure if you plan on pulling a permit or what. 6x6 posts are required now over 4x4. Some may say that's overkill for a low deck but I wouldn't mind the extra stability. Also, the beams must rest ON the posts and must be fastened w/ through bolts. If you look at the link I posted w/ the pdf you'll see where the differences are.
Your dump won't take wood with nails on it? That sounds really odd.. that can't be right. PT wood has some nasty **** in the wood, and burning it is a very bad idea. I would call up your dump again and see what they recommend for disposing of PT wood. When people demo things they don't go and individually pull nails and screws out of each board.. something sounds off.
"I wouldn't build a deck without the posts resting on the support posts.
There's not enough shear strength the other way"
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-25-2013, 06:58 PM   #161
Rewards Points: 588
I got the tension ties and bought 2- 2' long threaded rods which I think will be plenty long enough. The 3 footers seemed a little bit to long. I now have everything ready to go minus the concrete which I am getting the day we will use it.
In the near future after the deck is completed I want to add gates to block both sets of stairs. I have seen a few online but they seem to all be in the 36"-42" range and one of my stairways will be 6' wide. Any ideas where to get a gate that wide even if its a double? I plan on leaving them open all the time except when my daughter, and possibly another child by the end of the year, are out there with us. We don't use our back yard much because its pretty much in the woods and poison ivy grows all around the perimeter. With this deck we can go out there a lot more often though!
Old 02-25-2013, 07:04 PM   #162
Not so new
12penny's Avatar
Rewards Points: 520
2 36" gates would be fine.
May need a center post for
them to close against. Then
you can open one side or the other.
Old 02-25-2013, 07:19 PM   #163
Rewards Points: 588
Thanks. I saw pictures of double gates that latch to each other but I didn't see the right sizes. I will search again to see if I can find it. It looked just like my hand rails so it would be perfect if i can find the right size. Other staircase will be smaller, close to 5' I think, so it might be harder to find a gate for it. Someone online suggested using a regular vinyl fence gate which was a good idea also. I assume I can just screw through the vinyl sleeves and into the 4x4 for the latches pretty easily.
Old 02-25-2013, 07:29 PM   #164
Rewards Points: 588
This would be perfect. Not sure how it stays closed though.
Old 02-25-2013, 07:53 PM   #165
Not so new
12penny's Avatar
Rewards Points: 520
If you zoom on it, there's
a pin on each one that drops
into a hole in the deck board.
You only need on side
stationary though and a simple
gate latch on the other.
Building rooftop deck dwt Building & Construction 4 07-22-2011 04:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
