Deck Builders, Need Your Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 01:58 PM   #1
After months of procrastinating I finally have a design for the deck I want to build. I designed it according to the IRC Deck Construction Guide but I would really like some comments from someone who has done this a few times. Main question: Does this look structurally sufficient? Thanks for your help.
I have two sketches posted at:
http://www.scribd.com/doc/22337585/Deck-Design
Summary of design is
Freestanding
28' long, against house
13' 4" deep
24" above grade
Beams and deckboards perpendicular to length
4 beams attached to 8 piers (no posts)
Beams: doubled 2X10 PT SYP
Beam span 10'3" with 1'6" and 1'7" cantilevers
Beam spacing 8'
Joists: 2X8 PT SYP
Joist span:8' with 2' cantilevers
Joist spacing: 16"
Deck boards: 5/4X6 Siberian Larch
ericb1960 is offline   Reply With Quote
Old 09-22-2010, 05:13 PM   #2
Registered User
Rewards Points: 5,516
Couldn't see the diagram after 1 minute waiting. Joists are fine, beams are 1610# loaded good for 2376#, ok there. Remember to dig the footings within 5' of the house at least as deep as the house footings on undisturbed soil, as per Deck Code. Be sure to get a permit for liability in case of accident with paper trail for H.O.Insurance carrier. Waiting for the pic's!
Gary
Old 10-05-2010, 10:09 AM   #3
Gary,
Thanks for the tips. Sorry that the previous link didn't work. I uploaded the drawings to another file host. Any other comments or suggestions from you guys would be great.
http://www.mediafire.com/?pc8s0lnmvs81zgp
Old 10-05-2010, 09:01 PM   #4
jlhaslip's Avatar
Rewards Points: 2,186
20" diameter footings seem a bit small. Not sure where you are, but the footers here would be 32" square or larger.
And 24" overhang on the joists is probably a bit long. Shorten that up to about 16".
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 05:09 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Deck - 45 spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 10:28 AM
