Deck Builder - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 09:55 AM   #1
deck builder
I have a 18 by 28 deck with a 24' dormer extending 8' over the deck from the house. The dormer is setting on two beams with a 4*4 supporting each end of the 24' trusses. the 4 by 4 are wrapped with the trex sleeves. I under stand the axial compression is 1200 lbs per sq in. Will the 4 by 4 support the weight. Snow load?
medic15afd is offline   Reply With Quote
Old 06-19-2011, 01:00 PM   #2
Civil Engineer
Rewards Points: 4,706
If you want any realistic consideration of your question, you need to post photographs and a drawing of your setup. Even then, are you seriously going to take advice from an online chat group regarding what may be a potentially critical support on your house? Might be a good time to hire an engineer or architect to examine your setup.
Old 06-19-2011, 01:31 PM   #3
Framing Contractor
Why are you asking this after it has been built?
Joe Carola
Joe Carola is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
very unhappy with the job my deck builder did - Q's dtran Building & Construction 17 06-08-2008 12:43 PM
