Deck Boards Upside Down - Cupping - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 08:14 AM   #1
Rewards Points: 201
Deck boards upside down - cupping
So long story short, thought the wood should be installed bark side up but apparently the common way is opposite. I thought the wood would cup "with" the rings - I guess not. All of my boards are now "upside down".
Deck is 16x18 and I don't really want to but if I need to, I can flip them. Is it worth it or will it be ok? I can notice a bit of cupping already...
Thank you!
NickWa is offline   Reply With Quote
Old 05-31-2012, 08:29 AM   #2
Rewards Points: 3,130
Well, how much does it rain where you live? If a lot, I'd flip the boards. If not much, maybe not. But the job shouldn't be that hard.
Old 05-31-2012, 08:34 AM   #3
robertcdf's Avatar
Actually it's "Best looking side up" when it comes to wood, but then again wood does what wood does, in other words it cups, bows, splits, cracks, etc.
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
Willie T (06-04-2012)
Old 05-31-2012, 08:40 AM   #4
Rewards Points: 201
Thanks for the info guys.
I am in Ontario Canada so not terribly wet/humid but we do have pretty significant weather variances between summer and winter.
I bought a lot of extra wood and chose the best ones with best side up but made sure that the best side was the bark side. All of the boards look good how they are but they are all bark side up.
We won't be in this house for more than 2 more years so longevity isn't a concern but the quality of my work does matter and I would hate for it to be terribly cupped in 1 season.
I know it isn't hard to do but it is a LOT of screws to remove and re-screw.
If it isn't that big of a deal, I will certainly just leave it as is.
Old 05-31-2012, 08:52 AM   #5
DIY or die !
Rewards Points: 77
Just curious... How deep are your footings there in canada?
lewisthepilgrim is offline   Reply With Quote
Old 05-31-2012, 09:01 AM   #6
Rewards Points: 201
48" + to get below frost.
Old 05-31-2012, 10:14 AM   #7
Rewards Points: 2,212
Depends on where in Canada, It is a big country. some places go 8', I have even heard of some going 10'.
mae-ling is offline   Reply With Quote
Old 05-31-2012, 03:47 PM   #8
Haverhill Trade 1965
If the deck gets a lot of sun the exposed side dries and shrinks causing cupping. If you turn them over they may just do the same thing again.
Duckweather is offline   Reply With Quote
Old 05-31-2012, 05:00 PM   #9
kwikfishron's Avatar
Rewards Points: 824
A statement like that is like comparing all non-wood decking to Trex.
kwikfishron is online now   Reply With Quote
Old 05-31-2012, 06:37 PM   #10
robertcdf's Avatar
Are you saying that wood doesn't cup, bow, split, crack, etc? (when exposed to the elements in a exterior environment)
Old 05-31-2012, 10:35 PM   #11
Registered User
Rewards Points: 526
#9: http://bct.eco.umass.edu/publication...ns-about-wood/
Gary
The Following 3 Users Say Thank You to Gary in WA For This Useful Post:
kwikfishron (06-01-2012), mae-ling (06-01-2012), Nailbags (06-04-2012)
Old 06-03-2012, 10:04 PM   #12
Originally Posted by GBR in WA View Post
After reading the article I was surprised at how much of it I knew from experience, and reading. The one thing that caught my attention was the 50 year warranty. I wasn't wondering if the process would perform that long, but if the company would. The best advice I can think of came from the first framing crew I worked on. When nailing or screwing the lumber, the fasteners should go as close to the edge as possible. For decking that would be no more than 3/4" from the edge. It is much harder for that 3/4" to cup than 2", and fasteners near the center do little. whichever side dries faster, shrinks faster. Even more important was fastening 2 pieces of lumber together, i.e. studs & jacks, sister joists, etc. All the outside edges shrink faster than the adjoining surfaces and they cup away from each other. One major cause of drywall screw pops. All things considered I favor wood, and Trex is my lowest choice for composit decking compared to others
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
sticky deck boards rookie2012 Painting 4 09-13-2011 10:57 PM
Underdeck shed , can i roof w/pt plywood & put deck boards to it? BigTy General DIY Discussions 6 05-25-2011 01:45 PM
Deck boards on pt plywood? BigTy Carpentry 2 05-23-2011 08:35 AM
What kind of deck boards to use? wisbass Carpentry 16 02-03-2009 03:16 PM
