Deck Board Straightner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 12:07 AM   #1
Rewards Points: 616
deck board straightner
was looking for opinions on people who have used them like hitra's, deck devil, tiger jaw, bowrench.stanleys board bender,and hardwood wrench
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-15-2012, 12:37 AM   #2
Rewards Points: 12,830
I have two of the Stanly branded ones. I feel a 12" pipe wrench works just as well instead of spending to money to buy one.
Old 07-15-2012, 09:24 AM   #3
Civil Engineer
Rewards Points: 4,520
I used a bowrench on my deck, it worked beautifully. I was working with ipe, very strong, and there is simply no way I could have straightened some of those boards without a mechanical device. One of the things I liked about the bow wrench was that it locked in position, so I could do the job solo. Only downside is that the tool needs a certain amount of space to work, so could not be used on the last couple of boards towards the house, which I used a pipe clamp on.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
jaydevries (07-15-2012)
Old 07-15-2012, 09:30 AM   #4
If you talking about installing deck boards, we have been using a ratchet strap.
Does not leave a mark, I can span over 20 ft., super strong.
(plus I already had them so did not have to spend any money)
Old 07-15-2012, 09:41 AM   #5
Rewards Points: 616
i used to do the ratchet strap always ratcheting and fighting the lift issue then i switched to pipe clamps on a 10 pipe. then went to dadoing out 1 5/8 wide at 18 inch long board and using a large irwin spread clamp. now i am looking for suggestions for event a possible better solution. next deck i am looking at is going to use true 1x10 white oak in a barn
Old 07-15-2012, 05:56 PM   #6
dpach's Avatar
X2 on the Bowrench. Really helped and easy to use both pushing away from you and pulling towards you since you can change the pieces around for either use.
dpach is offline   Reply With Quote
The Following User Says Thank You to dpach For This Useful Post:
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 12:26 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 10:46 PM
Re-attaching Deck to Ledger Board B-Web Building & Construction 5 12-13-2010 09:05 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
