Deck Board Layout Question - With Pictures - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 07:33 PM   #1
deck board layout question - with pictures
I need to cut out for two 4x4 posts. what is the best way to lay out these cuts.Please refer to posted picture
[ATTACH]BE207@TDS.NET56662[/ATTACH]
BEN CUNDIFF is offline   Reply With Quote
Old 08-31-2012, 07:52 PM   #2
Rewards Points: 13,994
Your missing some blocking to support the decking around the post.
Also those post need to be trough bolted not just nailed.
When I have to cut one like that it's just a matter of lots of measurement and a speed square to lay it out.
Old 08-31-2012, 11:30 PM   #3
For cutting the board, I would line the piece up square to where it will sit, and use a framing square against the deck framing to transfer the angles. One of those cuts you just need to take your time to make it pretty.
chrisBC is offline   Reply With Quote
Old 09-01-2012, 08:32 AM   #4
Rewards Points: 150
What kind of gap do you have between the deck boards?
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
The Following User Says Thank You to Hammer450R For This Useful Post:
BEN CUNDIFF (09-01-2012)
Old 09-01-2012, 08:41 AM   #5
Rewards Points: 150
I would cut the piece to length, then i would measure along the cut till i hit the 4x4, then use my square on the cut to mark the 4x4. Continue the measuring right around the 4x4.
Old 09-01-2012, 09:49 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
As everyone mentioned, get your cut figured out with a straight edge. add joist blocking around both posts to hold up decking, bolt posts to deck and drop the deck board in from above and slide it down the posts till it sets down tight at the spot... though, it looks like it might just be two v cuts depending on where 5 1/2" lands on the posts so that will actually be easier than trying to cut around multiple sides of the posts.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Old 09-01-2012, 10:02 AM   #7
The gap is the width of the srews i am using. New boards not the same size as old boards. Had to make adjustments
Old 09-01-2012, 10:11 AM   #8
AHH, SPANS!!!
a carpenters speed square is the best on site tool for those type situations and if it is not long enough to reach then use a carpenters pencil to lengthen the straight edge point. I use a standard size speed square and have the 12" square in the truck for the other times it is needed along with a framing square...
how far is it from your last deck plank to the outer deck band inner edge? be sure and measure both sides for maximum accuracy.
Old 09-03-2012, 11:26 PM   #9
I had to do something similar for my deck and used a super low tech.
I just used scrap pieces of cardboard to make a simple template, then traced it on to my wood for a final cut.
allthumbsdiy is offline   Reply With Quote
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 09:46 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
deck question toddj99 General DIY Discussions 5 04-24-2010 10:12 PM
Deck Ledger Question Greg D Building & Construction 9 04-08-2010 07:57 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
