Deck Board Gap? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2007, 09:59 PM   #16
Commercial Contractor
Spacing, or staining
All pt lumber dries at a different pace. One sure way to find out if it is dry or not (for spacing or for staining purposes) is to try the water test. If you place a drop of water on the pt and it soaks in quickly then it is dry. It could of been sitting at the retailer for months who knows.
The professional is offline   Reply With Quote
Old 06-14-2007, 04:29 AM   #17
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are really concerned about the moisture content of your PT lumber to be used....you could always, just get on Amazon and order yourself a ''moisture meter''. We have one that we use alot for moisture damage work.....
- Build Well -
Old 06-15-2007, 07:41 AM   #18
Rewards Points: 530
Difference in moisture content seems to be evident when loading and unloading pt lumber. Significant difference in the weight of same sized lumber.
Old 06-20-2007, 10:23 PM   #19
Rewards Points: 774
So, what are the consequences should the deck boards be dry and I butt them together anyway? It is tough to tell on these boards. I got them from a big box store, so there is a good chance they sat around for awhile. I'm just not sure if they sat there long enough to dry out.
I even thought to be on the safe side, I could use a trim nail as a spacer just in case.
cibula11 is offline   Reply With Quote
Old 06-21-2007, 11:45 AM   #20
Rewards Points: 774
Anyone with any last opinions??
Old 06-21-2007, 07:43 PM   #21
Yes, Please stop obsessing and over-analyzing this. It's actually been answered already; Side by side, no gap.
Really now: It's a pressure treated deck for goodness sake, it's not a piece of museum art. The only thing that's going to get close to the deck = is people's feet - while they are walking on it.
Once it's all done, seriously, NO-ONE is going to notice whether the boards are 1/8" spaced or 3/8" spaced, while they're eating their hamburgers & hotdogs, listening to music and watching fireworks....
- Build Well -
Old 06-22-2007, 04:59 AM   #22
Thumbs up
Good Answer Atlantic
Old 06-25-2007, 10:11 AM   #23
Rewards Points: 774
sorry.
thanks for the reminder
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Hide deck board ends bardad1022 Carpentry 4 06-08-2007 08:55 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
