Deck Board Gap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2007, 09:41 AM   #1
Rewards Points: 790
Deck Board Gap?
I will soon be constructiing a new deck and will be using PT 5/4 x 6 boards for my deck planking. I have heard conflicting views on whether to gap the boards when laying the decking. Some say you need to gap 1/8" or so and others say to butt the boards tightly to one another. Which is correct?
cibula11 is offline   Reply With Quote
Old 06-06-2007, 09:48 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
PT deck boards: NO GAP.
Place the deck boards side by side.
(Check for alignment every 6 boards out, or so - If it's a long length deck board arrangment. You could also pre-snap reference lines over the joists prior to the start of the decking work).
Pressure treated deck boards, as is the case with all PT lumber, shrinks considerably after it is installed and slowly dries out.
Deck boards placed side by side will give you 1/8" to 3/8" gaps between the boards when it is fully seasoned (3-6 months)
- Build Well -
Old 06-06-2007, 09:56 AM   #3
Rewards Points: 530
Just read an article about some pt being predried now. In that case, shouldn't a gap be left beyween the boards? Like maybe a nail used as a spacer?
Old 06-06-2007, 10:00 AM   #4
Pre-dried, yes.
- Build Well -
Old 06-06-2007, 10:03 AM   #5
Rewards Points: 790
Most PT is not pre dried, correct? So I should NOT leave a gap? That's what I thought, but some were saying that it would be a drainage problem if no gap was left.
Old 06-06-2007, 10:13 AM   #6
I am more worry that small animals find a comfort home and decide to stay there if there is no gap... but then a no gap deck must be very comfy...
KUIPORNG is offline   Reply With Quote
Old 06-06-2007, 10:14 AM   #7
Regular PT, that is not sold specifically as "Pre-dried" = place side by side.
Specific "Pre-dried" PT, talk to the supplier to ascertain exactly what that labeling means in terms of the decking they are calling "pre-dried"...Their definition of this....
- Build Well -
Old 06-06-2007, 11:27 AM   #8
I get PT decking as tight together as I can.
RYANINMICHIGAN is offline   Reply With Quote
Old 06-07-2007, 09:11 AM   #9
Rewards Points: 790
Thanks everyone!
Old 06-08-2007, 07:59 AM   #10
Extreme DIY'r Adk's, NY
Rewards Points: 272
I doubt you will find predried, depending where you are. You can tell the difference by weight too!
crecore is offline   Reply With Quote
Old 06-08-2007, 09:08 AM   #11
Rewards Points: 790
If I don't gap the boards, when they expand, will the boards cup and warp since there is no gap?
Old 06-08-2007, 10:09 AM   #12
I remember reading from the web that nowaday, they don't gap, and they don't expand no more... gap is for old days installation...etc... forget where reading those though...
Old 06-08-2007, 04:14 PM   #13
Cib,
They Don't expand, they shrink as they dry.
- Build Well -
Old 06-11-2007, 08:51 AM   #14
Long-Time DIYer
Mike Swearingen's Avatar
IF you have p-t wood that is stamped KDAT (for Kiln-Dried After Treatment), then you can leave a nail size gap, otherwise butt the deck boards tightly together and they will leave a nice drainage gap when they dry out.
Most p-t wood is allowed to "drip dry" on a concrete pad (that drains the excess chemical back into a recycling pit) at the manufacturing plant, and the moisture content stays pretty high for a long time. Most manufacturers recommend - for best results - allowing up to 6 months for the p-t wood to dry out in place before staining or painting.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-11-2007, 11:13 AM   #15
Rewards Points: 530
Brings up another question, but I wll make seperate post for it.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Hide deck board ends bardad1022 Carpentry 4 06-08-2007 08:55 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
