Deck Beam Splicing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 04:41 PM   #1
Deck Beam Splicing
I know this is beating a dead horse so I'll ask short and simply. Should beam splices meet and be set over the support posts or staggered and offset?
Posts or pilings are 8 x 8, 10' o.c. and notched for beam to rest on.
Beam is 2 - 2 x 10's
MisterSteve is offline   Reply With Quote
Old 09-28-2012, 05:37 PM   #2
joed's Avatar
Rewards Points: 12,018
All joints over the support posts.
Old 09-28-2012, 05:40 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
good question ...... in days of old we used spliced beams. they can be used today but would require evaluation by a professional engineer to ensure they are built correctly.
now with the new building code it has been interpreted based upon the span tables for beams only providing simple span that all beam splices should occur over the supports. now let's say you're using a three ply beam and the width of your deck is 20'. my understanding is you could have two 20' members (using your 10' span example) and a center member that is 10' in length. this way all splices are occurring over the supports. where there is a splice (two members abutting one another) they must occur over a support.
I do not believe it means that every ply must be spliced at each and every support. Your building official though is the one that has the final say, so ask them .....
hopefully Daniel Holzman will read your post and provide feedback as he is our resident professional engineer.
for some additional information in regards to decks I recommend checking out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide" which is based upon the 2009 International Residential Code, basis for most local and state building codes. http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-28-2012, 06:09 PM   #4
Split your beams on the post. You should use a st12 to hold the beams together.
Rocket98 is offline   Reply With Quote
Old 09-30-2012, 07:28 AM   #5
What is st12?
Old 09-30-2012, 09:29 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by MisterSteve View Post
What is st12?
Simpson Strap Tie: http://www.strongtie.com/products/co...S-HST-LSTA.asp
- Build Well -
Old 09-30-2012, 11:27 AM   #7
Civil Engineer
Rewards Points: 4,572
According to International Residential Code (IRC) 2006 or 2009 Prescriptive Deck Code, which governs most (not all) decks in the U.S., all splices must occur over a post. See figures 3 and 4 for details. Beam construction is shown in the guide, and requires only nailing the individual sawn lumber pieces together following the nailing schedule shown on Figure 4. Figure 8 shows the required connection between a post and a beam. Nothing in the code requires use of a Simpson ST12 to hold the beam together, your local requirements may be different, check with your building inspector.
Beam supports for 8'x12' deck with roof EmilyS Building & Construction 9 05-07-2012 10:15 AM
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 08:23 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Deck Beam Question usmcstormvet Building & Construction 5 08-28-2008 05:48 PM
