Deck Beam Splice Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 04:08 PM   #1
Newbie Bill
Rewards Points: 520
Deck beam splice question
Hey Guys,
Rebuilding my deck and have a question about my deck beam. The beam is 17 feet long and will be a double 2X10 pressure treated. Three posts with the two outside posts in about 12 to 18 inches from the end resulting in the beam being cantilevered. See below.
I cannot find any pressure treated lumber longer than 16 ft. For that matter, I can't find any dimensional lumber around town longer than 16 feet. So that means I am going to have to splice my beam. The only place to do that is on the middle post so both splices will be together sitting on that middle post. I'd like some expert comments onthat.
Is this OK or should I look for 17 foot manufactured beam. Glue lam or whatever they are called. Remember this is outside.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-21-2009, 04:59 PM   #2
So you are using the existing posts w/new beams?
What were the old beams?
Old 07-21-2009, 06:28 PM   #3
Newbie Bill
Rewards Points: 520
Yes, I am using the old piers, new posts on the piers. And I can't remember if the beam was one piece or if it was built up. Doh...
Bill
Old 07-21-2009, 08:24 PM   #4
Registered User
Rewards Points: 5,482
1. How high off the ground?
2. What is the joist span to the next bearing?
3. What size, species of floor joists?
4. What size posts?
5. Is it attached to the house?
The tension, compression on the two piece beam needs to be addressed for a Simpson post cap, possibly by an Engineer. Give us the other info. first, please. Be safe, G
Old 07-21-2009, 08:44 PM   #5
Newbie Bill
Rewards Points: 520
I have answered the questions below in red.
Originally Posted by GBAR in WA View Post
1. How high off the ground?Bottom of beam is 13 inches off ground
2. What is the joist span to the next bearing?10 feet, which is to code here
3. What size, species of floor joists?2X8 pressure treated spruce, again is code here
4. What size posts?4X4 posts.
5. Is it attached to the house?Yes
Bill
Old 07-22-2009, 01:29 PM   #6
Registered User
I'm not an engineer. I would imagine they would recommend two post caps like this: On each side- AC: http://www.strongtie.com/products/co...E-LPCZ-LCE.asp With a flat strap as a MST27 on each side: http://www.strongtie.com/products/co...S-HST-LSTA.asp Be safe, G
Old 07-22-2009, 01:54 PM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
Can't you special order a 20' 4x8? It will probably cost $100 but it may be worth it if you don't have to think about the splice.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-22-2009, 02:28 PM   #8
General Contractor
Check with 84 lumber they may have 20' in stock. I remember seeing some 20' 2x10's and 2x12's in the lumber area at one about a year ago. May have been a special order for someone though.
ARI001 is offline   Reply With Quote
Old 07-22-2009, 07:00 PM   #9
Newbie Bill
Rewards Points: 520
I checked with the "specialty" lumber yards around here. The owner of one store said he would have order a lift of them.
We don't have 84 Lumber stores here in Canada. I will make a few phone calls to a few other lumber places.
GBAR, I already picked up 6 of those AC Strongtie post caps. I'll look into the strapping if I can't find a 20 footer anywhere.
Bill
Deck question for complete DIY NEWBIE. What tools do I need? dignan99 Carpentry 15 06-20-2009 04:31 PM
Deck beam Question ovahimba Building & Construction 7 06-05-2008 08:54 AM
Setting a deck beam directly on footings ovahimba Building & Construction 1 01-10-2008 01:57 PM
Deck Posts question flyultralite Building & Construction 1 06-23-2007 09:18 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
