Deck Beam To Post Connection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 03:31 PM   #1
Deck beam to post connection
Does anyone know how much of a beam must be resting on a support post? I will have 3 beams, each one being 2-2x10s and intersecting at one 8 x 8 post. Two of the beams will rest at a 90 degree angle and the third will rest at 45 degree angle at the point of the other two beams. I will post a pic of a mock up i made.
MisterSteve is offline   Reply With Quote
Old 10-21-2012, 04:08 PM   #2
Rewards Points: 14,312
What are these beams holding up.
Without a picture were lost.
Old 10-21-2012, 05:21 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
MisterSteve,
this link will provide you the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." The information contained is based upon the 2009 International Residential Code, the basis for most local/state building codes.
As far as bearing requirements here is what the 2009 IRC requires:
R502.6 Bearing. The ends of each joist, beam or girder shall have not less than 1.5 inches (38 mm) of bearing on wood or metal and not less than 3 inches (76 mm) on masonry or concrete except where supported on a 1-inch-by-4-inch (25.4 mm by 102 mm) ribbon strip and nailed to the adjacent stud or by the use of approved joist hangers.
typically I bear my beams fully on columns.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Floor Flex with Car Deck / Post & Beam Construction george779 Tiling, ceramics, marble 3 05-09-2012 06:36 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 07:23 AM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 09:35 PM
