Deck Beam To Post Attachment Question. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 08:57 PM   #1
Rewards Points: 105
Deck Beam to Post attachment question.
For my 18'x30' monster deck, the span tables call for using (3) 2x12s as a beam. What is the best way to attach them to the 8"x8" post? I figured I would notch the post and be able to use 1/2" or 5/8" carriage bolts to secure the beam to the post but, what about when the beam is dog-legged?
Bugman1400 is offline   Reply With Quote
Old 03-18-2013, 09:04 PM   #2
Use 2 posts a little away on each side of the dog leg
rckkrgrd is offline   Reply With Quote
Old 03-18-2013, 09:43 PM   #3
Rewards Points: 13,300
May have to have a custom made bracket made for that one.
Any real machine shop could make it.
Old 03-18-2013, 11:59 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I think that even with three plys of 2xs you would be fine in notching the 8x8 posts. Sounds like it will have plenty of bearing.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-19-2013, 08:31 AM   #5
GBrackins's Avatar
Rewards Points: 2,108
may ways to do this, you could notch out 3" from the column (leaving 4-1/2"). the inner two plies would bear directly on the column. the outer ply would be supported either by a wood cleat attached to the face of the column or metal connector made for this situation.
could pad out the beam to the same depth as the column (pad out at the column) and use metal column caps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Another deck beam span question Bugman1400 Building & Construction 26 02-28-2012 02:25 PM
Another Deck Question...Gable Roof Post Placement Issues. mgh-pa Building & Construction 2 06-02-2011 07:26 AM
Post and beam attachment DIY1963 Building & Construction 5 07-25-2010 09:25 AM
Deck Beam Question usmcstormvet Building & Construction 5 08-28-2008 05:48 PM
