Deck Beam Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 10:06 AM   #1
Deck beam construction
I have 4 8 inch concrete piers spaced @ 6' 7 inches apart and would like to construct a double 2x10 beam 24' long
That would give me 2 foot overhang on each end
I have 14' 2 x 10
Where and how would I join them?
Fatboymm is offline   Reply With Quote
Old 05-08-2012, 10:38 AM   #2
Civil Engineer
Rewards Points: 4,526
Typically beam splices are required to be aligned over a post, see Figure 3 of the International Residential Code for deck design, 2006 edition. If you are not building to this code, your requirements may be different. Beams composed of multiple lumber members are assembled in accordance with Figure 4 of IRC 2006, which shows the required nailing pattern and nail size. Maximum beam cantilever is in accordance with figure 3, which allows Lb/4 maximum, where Lb is the c-c distance between posts. In your case, you state the posts are 6'7" (79 inches) c-c, so maximum overhang is 19-3/4 inches according to IRC code, so your proposed 2 foot overhang would not be acceptable.
Again, if you are working to a different code, this may not apply. If you hire an engineer to design the deck and stamp the plans, you are typically allowed to deviate from code. Your local building inspector is generally permitted to allow you to deviate from code, so you may wish to consult with them in advance if you cannot live with code requirements.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
AndyGump (05-08-2012)
Old 05-08-2012, 06:50 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
a 2 ply beam is pretty flimsy. the only time ill use a 2 ply is if its a deck thats 4' x 4'. which is directly off a entry door. anything larger and you need a 3 ply or even 4 ply
woodworkbykirk is online now   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Beam Construction kemp Building & Construction 4 09-14-2009 11:26 PM
Deck Beam Question usmcstormvet Building & Construction 5 08-28-2008 05:48 PM
